Results Page Error
Thread begun 9/13/2012 8:03 pm by elewis93815 | Last modified 9/14/2012 12:05 pm by elewis93815 | 2979 views | 5 replies |
elewis93815
Results Page Error
We have created a results page via the Data Assist Pages Wizard. When we upload and test the results page (the only page we ran) we get an error: Parse error: syntax error, unexpected ';' in /home/content/m/i/s/misterel/html/appreciation/ab_results.php on line 128
I'm not sure what or where we went wrong, it appears to be a show if element on the page but I'm not sure????
I've attached the relevant pages. Any assistance would be greatly appreciated!
Thank you,
Jackie
line 128 :
<?php if ($totalRows_WADAab &gt; 0) { // Show if recordset not empty ?>
should be:
<?php if ($totalRows_WADAab > 0) { // Show if recordset not empty ?>
elewis93815
Thank you Jason for your reply. We did change the line of code that you referred to, however, two things we've noticed:
1. When we put the page up we are seeing the page with no records found (Records 1 to 0 of 69)??? Also, in the server behaviors of this page we are seeing a red ! next to the DataAssist Repeat Selection. I've attached a screen shot of the error.
At any rate, we have data to be retrieved, but it is not coming back in a search or by running just the results page to show all records.
What version of Data Bridge do you have installed?
Please make sure you are using the latest version 1.0.8, if you have a previous version, you will need to uninstall it from the extension manager beofer installing the new one and then delete and regenerate the data assist pages.
the issue you report seams like something that was fixed in the newer release, also, make sure to Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
elewis93815
We were using version 1.04, are we going to need to re install all of our WA plugs? I know that Ray instructed us to install them based upon a specific sequence?
Thank you!
Jackie
elewis93815
Originally Said By: elewis93815
Thank you!
Jackie
You can ignore my last post I see the notes in your download section that we will need to uninstall all of our WA plugs. - Jackie
