User Level Authentication
Thread begun 9/13/2012 12:40 pm by tolushayoo193471 | Last modified 9/14/2012 10:53 am by Jason Byrnes | 4395 views | 7 replies |
tolushayoo193471
Hi, am trying to restrict access to some pages, I've created the access level by following security assist user level help file. I hve to level Administrator which is 3 and staff which is 5. I've followed the tutorial step by step successfully, uploaded it to my sever to test it, if i login with the username and password for admin or for staff it's not login me in. Please help I dont know why it's not working.
thanks
send a copy of your login page please and the webassist/securoity_assist/helpergrouprules_php.php file
tolushayoo193471
thank you, please find the attached.
in the authenticate user behavior, on the database tab, remove the User level condition. the user level should be included as a condition to login.
the user level is saved to a session, and that session is used to restrict access.
tolushayoo193471
thank you jason, I've now done what you said, it works now but the access level is not working properly
1) it's allowing the staff to login but have access to page that is only meant for the administrator
2) it's not login the administrator to login at all
1) Send a copy of the page intended for admins
2) to troubleshoot, add the following to the login page:
echo("<pre>");
var_dump($_SESSION);
echo(
"</pre>");
after trying to login it should show the sessions that are set and their value. What are they?
tolushayoo193471
it bring out "NULL"
see the attached admin page
