ssl again - different issue
Thread begun 9/12/2012 6:32 am by johna1964 | Last modified 9/12/2012 12:49 pm by johna1964 | 1730 views | 2 replies |
johna1964
Hi!
After all this time, I finally placed recommend buttons on the site.
I am using http; however, when using the google search (unfortunately not WA yet, but more than likely will as soon as possible and basically the same as the WA google search in free tools), all search results return with the https url, causing the annoying security warning.
Is there a way around this?
Thank you!
johna1964
use the https address in the recommend buttons instead of the http address.
johna1964
Hi Jason,
I am using http... it is an issue with the Google Search...
Thank you for you help :)
johna
