Login no longer working
Thread begun 9/11/2012 8:15 pm by diamou_fr200291 | Last modified 9/12/2012 6:02 pm by diamou_fr200291 | 1977 views | 2 replies |
diamou_fr200291
I've been using Security Assist without any problem until now. My hosting provider has upgraded the php version from 5 to 5.2 and there is one new recent update to 5.3.
These changes have made my log in pages no longer working even if the log credentials are correct. Could you please help me to solve this issue?
Thank you in advance
i bet when they did the upgrade, the did not set the session.save_path variable in the php.ini file to enable sessions on your site.
to test this, use the sessionTest.php file from the following thread:
showpost.php?p=23826&postcount=2
if the session test fails, you will need to contact the host to have them correct the problem in the php.ini file by setting the correct session.save_path
diamou_fr200291
Hi Jayson,
I have followed your instructions and realized that they did not set the session.save_path correctly. Now everything is working fine again.
Thanks for your support!
