DB update after stock purchase
Thread begun 9/11/2012 7:44 pm by rogersds267040 | Last modified 9/13/2012 11:24 am by Jason Byrnes | 3089 views | 5 replies |
rogersds267040
The stock column in the database does not get updated when a purchase is made from the website.
What payment gateway are you using?
Is the store set to use test mode?
or is the gateway set to use the sandbox?
rogersds267040
Payment Gateway is uncheck and Test Mode is not selected.
is the order being stored in the database?
if you go to the admin section, can you see the order under the orders tab?
rogersds267040
Yes sir, the order shows up under the New Order tab.
