No record found
Thread began 9/11/2012 7:51 am by atstech | Last modified 9/11/2012 8:50 am by Jason Byrnes | 541 views | 1 replies |
atstech
No record found
After pressing the Insert button on index_Ad_Insert.php, the values are entered into the database but the redirect to index_Ad_Detail.php page shows No record found.
I have tried:
Clearing cache
Deleting Extension
Downloading and reinstalling Extension
Re-running DataAssist Wizard 6+ times
I tried swapping out the library.php files with another site I knew was working.
I cannot find why this is happening and now I am getting very strange results when running the Wizard. Any suggestions on what else I can try to get back to working normally?
DA-noDetail.zip
on the insert page, try cahnging:
$_SESSION[$WA_sessionName] = mysql_insert_id();
$_SESSION[$WA_sessionName] = mysql_insert_id($WA_connection);
atstech
Thank you for your reply. I tried this and it still does not work. I am still receiving No record found after inserting. I also looked at some other sites created with DataAssist and they show $_SESSION[$WA_sessionName] = mysql_insert_id(); with no adjustment needed. I don't mind altering the code to see if it works but I would prefer the DA Wizard to work correctly.
**Update**
Further testing showed that this problem happens only when I choose to apply a template. In testing I found a session_destroy() that was not needed so by removing it the problem seems to be fixed. Thank you for taking the time to suggest a solution. Looks like this issue is now resolved.
