Wrong image showing ID mixed up
Thread begun 9/10/2012 6:04 pm by illbe322016 | Last modified 9/11/2012 1:44 am by Morgan | 1844 views | 1 replies |
illbe322016
When the record displays it shows the wrong image, but oddly an image with the same numbers in the ID for example itemID 4086 will show image 4068.jpg if there is no 4086.jpg on the server. What am I missing here? I have an "onerror="this.src='images/default.jpg" rule in place but this only works if there is no image with similar numbering, for example itemID4063 shows the default.jpg image, I guess because there is no 4036.jpg on the server.
Thank you in advance
Tom
Morgan
Hi Tom, can you put up the page where you have the problem? Sounds like the sent parameter is wrong + that it adds the .jpg to your itemID. :)
"onerror="this.src='images/default.jpg" is that for showing if there is no image uploaded to the item? If it is, maybe you should change it to a "Show if" instead.
//Morgan
illbe322016
Here is the code
It seems that the DB is providing an image that is similar or "LIKE" the one requested, in other words it can't find 4086.jpg so it substitutes 4068.jpg, could that be??
Any help with this is appreciated, this is killing me :-)
i dont see any problems in the code
