Bad links from the "Next" and "Last" links
Thread begun 9/10/2012 12:30 pm by dDog | Last modified 9/11/2012 12:56 pm by dDog | 1072 views | 2 replies |
dDog
When I select a category from the drop down menu, the list is displayed correctly, however, when I click on "next" or "last" links for additional proucts the program is is not adding "http://sentryotc.com/..." info to the link which results in an error.
If I use the Search feature to find products the links work properly.
You can see this phenomenon at: sentryotc.com
Please advise as the site is live.
in the webassist/plugins/catyalog/results.php, results_grid.php and /basic/results.php files, find the following code:
if (!isset($currentPage)) {
$currentPage $_SERVER['PHP_SELF'];
else {
    if (
dirname($_SERVER['PHP_SELF']) == "/")  {
$currentPage =  '/' $currentPage;
    } else {
$currentPage dirname($_SERVER['PHP_SELF']) . '/' $currentPage;
and change it to:
else {
    if (
    } else {
$currentPage dirname($_SERVER['PHP_SELF']) . '' $currentPage;
dDog
Unable to upload permissions error
I made the modifications to the file in Dreamweaver and for some reason it will not allow me to upload the new pages - it returned permissions error as the reason. I tried outside of Dreamweaver using filezilla and I still cannot delete or upload. We had this problem with prior files (CSS) which we cured by deleting the file and reloading the new one, we were told this would reset the permissions. Any suggestions.
did you try deleting the original files from the server then re uploading?
if that doesn't work, you'll need to contact the host to have them correct the permissions issue.
