ecart summary
i am trying to save the information of the order in the database, but whet i chose de trigger button: press, doesn´t do anything, but if i chose before page load it safe all information.
Do you know the reason?
sounds like your using paypal standard or another remote checkout system
the conform page sends the data to the gateway on post, so only when the checkout page sends to the confirm page can you capture the posted information.
i used paypal configuration, but now i want to removed to use other provider servisers...how i can removid, i send you the the page what i have the problem.
delete the checkout and re run the checkout wizard to configure it to use a different gateway.
it does the same
it does the same what?
Can you provide more details please.
with de ecart summari option i trying to use the trigger button: press, doesn´t do anything, dont safe the information on the database. And i have another tigger wi webassite email with the same tigger button, and dont send de information.
you can see de page: productos-antiguas.php?categoriaID=1, in you want to try to by use this account: email:frandios@quiru.net, password: 11, it work all perfect, but i have this problem.
If the trigger chat to before upload, it works, but i need to safe de information with press boton.
it's because you are using a remote checkout system.
you cannot do what you want to do when using a remote checkout system, only when using a local checkout system can you trigger the behaviors on submit button pressed
i have to do it all again...there are another way to do it?
you can create the checkout manually, but it is simpler to use the wizard, far simpler to use the wizard.
