Remember me check box not working
Thread begun 9/09/2012 7:19 pm by chssagmi366905 | Last modified 9/10/2012 8:14 am by Jason Byrnes | 4281 views | 1 replies |
chssagmi366905
On my member login page my "remember me" login works but the checkbox isn't showing the check. This is my code: <input name="rem" type="checkbox" id="rem" <?php if (!(strcmp(((isset($_COOKIE["rem"]))?$_COOKIE["rem"]:""),1))) {echo "checked=\"checked\"";} ?> />
send a copy of the page please so i can see the code in context and a link where i can see the problem.
chssagmi366905
checkbox update
if ((((isset($_POST["rem"]))?$_POST["rem"]:"") != "")) {
setcookie("rem", "".((isset($_POST["rem"]))?$_POST["rem"]:"") ."", time()+(60*60*24*90), "/", "", 0);
setcookie("password", "".((isset($_POST["password"]))?$_POST["password"]:"") ."", time()+(60*60*24*90), "/", "", 0);
setcookie("username", "".((isset($_POST["username"]))?$_POST["username"]:"") ."", time()+(60*60*24*90), "/", "", 0);
<?php require_once("../WA_SecurityAssist/WA_SHA1Encryption.php"); ?>
<?php require_once('../connections/dbc.php');?>
<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
if(isset($_POST["LogIn"])){
$WA_Auth_Parameter = array(
"connection" => $dbc,
"database" => $database_dbc,
"tableName" => "tbl_users",
"columns" => explode($WA_Auth_Separator,"username".$WA_Auth_Separator."password"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".WA_SHA1Encryption(((isset($_POST["password"]))?$_POST["password"]:"")) .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"userID".$WA_Auth_Separator."rcode"),
"sessionNames" => explode($WA_Auth_Separator,"userID".$WA_Auth_Separator."rcode"),
"successRedirect" => "../redirect.php",
"failRedirect" => "mess_loginFailed.php",
"gotoPreviousURL" => FALSE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
// *** Validate request to login to this site.
if (!isset($_SESSION)) {
session_start();
$loginFormAction = $_SERVER['PHP_SELF'];
if (isset($_GET['accesscheck'])) {
$_SESSION['PrevUrl'] = $_GET['accesscheck'];
if (isset($_POST['username'])) {
$loginUsername=$_POST['username'];
$password=$_POST['password'];
$MM_fldUserAuthorization = "";
$MM_redirectLoginSuccess = "../redirect.php";
$MM_redirectLoginFailed = "mess_loginFailed.php";
$MM_redirecttoReferrer = true;
mysql_select_db($database_dbc, $dbc);
$LoginRS__query=sprintf("SELECT userID, password FROM tbl_users WHERE userID=%s AND password=%s",
GetSQLValueString($loginUsername, "int"), GetSQLValueString($password, "text"));
$LoginRS = mysql_query($LoginRS__query, $dbc) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
if ($loginFoundUser) {
$loginStrGroup = "";
//declare two session variables and assign them
$_SESSION['MM_Username'] = $loginUsername;
$_SESSION['MM_UserGroup'] = $loginStrGroup;
if (isset($_SESSION['PrevUrl']) && true) {
$MM_redirectLoginSuccess = $_SESSION['PrevUrl'];
header("Location: " . $MM_redirectLoginSuccess );
else {
header("Location: ". $MM_redirectLoginFailed );
// start session varible
session_start();
<head>
<title>Log In</title>
<link href="../styles.css" rel="stylesheet" type="text/css" />
<style type="text/css" media="screen">
@import url("../p7tbm/p7tbm_navy_06.css");
</style>
<script type="text/javascript" src="../p7tbm/p7tbmenu.js"></script>
<link href="../WA_SecurityAssist/styles/Modular_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="../WA_SecurityAssist/styles/Verdana.css" rel="stylesheet" type="text/css" />
function MM_goToURL() { //v3.0
var i, args=MM_goToURL.arguments; document.MM_returnValue = false;
for (i=0; i<(args.length-1); i+=2) eval(args[i]+".location='"+args[i+1]+"'");
</script>
<style type="text/css">
.style4 {font-size: 14px}
.style6 {font-size: 14px; font-weight: bold; }
</style>
</head>
<body onload="document.WAATKLogInForm.username.focus()">
<div id="container">
<div id="header">
<h2 align="center"><strong>Member Login</strong></h2>
</div>
<form ACTION="<?php echo $loginFormAction; ?>" method="POST" name="WAATKLogInForm" id="WAATKLogInForm">
<table width="55%" border="0" align="center" cellpadding="5" cellspacing="0" class="WAATKDataTable">
<tr>
<th width="28%" height="39"><span class="style4">Username</span></th>
<td width="72%"><input name="username" type="text" value="<?php echo((isset($_COOKIE["username"]))?$_COOKIE["username"]:"") ?>" size="40" maxlength="40" /></td>
</tr>
<tr>
<th height="43"><span class="style4">Password</span></th>
<td><input name="password" type="password" value="<?php echo((isset($_COOKIE["password"]))?$_COOKIE["password"]:"") ?>" size="40" maxlength="40" id="password" /></td>
</tr>
<tr>
<th height="43">&nbsp;</th>
<td><label>
<span class="style6">Remeber Me</span></label></td>
</tr>
<tr>
<td><a href="forgot_password.php"><span class="style4"><strong>Forgot Password</strong></span></a></td>
</tr>
</table>
<p>&nbsp;</p>
<div align="center">
<input type="Submit" name="LogIn" id="LogIn" value="Log In">
</div>
</form>
<p>&nbsp;</p>
<table width="25%" border="1" align="center" cellpadding="5">
<tr>
<td><label> </label>
<input name="redirect" type="button" id="redirect" onClick="MM_goToURL('plugins/parent','../redirect.php');return document.MM_returnValue" value="Homepage">
</div></td>
</tr>
</table>
<p>&nbsp;</p>
//--include footer--
include ('../includes/footer.inc.html');
</div>
</body>
</html>
chssagmi366905
checkbox update
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
session_start();
else {
session_start();
<head>
</style>
</script>
</style>
</head>
<div id="header">
</div>
<tr>
</tr>
<tr>
</tr>
<tr>
<td><label>
</tr>
<tr>
</tr>
</table>
<p>&nbsp;</p>
</div>
</form>
<p>&nbsp;</p>
<tr>
</div></td>
</tr>
</table>
<p>&nbsp;</p>
</div>
</body>
</html>
please dont paste the code like this.
instead compress the php page to a zip archive and attach the zip archive to your post.
chssagmi366905
Sorry thought you wanted others to see.
the rem checkbox:
does not have a checked value set:
<input name="rem" type="checkbox" id="rem" value="1" <?php if (!(strcmp(((isset($_COOKIE["rem"]))?$_COOKIE["rem"]:""),1))) {echo "checked=\"checked\"";} ?> />
