UE 401 statusCode error messages
Thread begun 9/08/2012 7:19 am by Paul | Last modified 9/11/2012 2:06 pm by Jason Byrnes | 2365 views | 3 replies |
PaulBeta Tester
I've been attempting to customise the file upload statusCode, one of which is below;
<?php if ($WA_DFP_UploadStatus["WA_UploadResult1"]["statusCode"]==1) { ?>Upload was successfull<?php }?>
I have followed the user guide for Digital File Pro.
when i apply this to my page and try to upload a file that conflicts with my upload rule, as a test, none of the statusCode messages reports any errors.
I should be seeing file size, width and height conflicts at least.
Is there a more recent guide for UE 4.0.1 that i should be following?
Thanks, Paul.
to help debug, go to the bindings panel, and expand the WA Uplaoded Files Global Status and add the Debug info binding to the page.
Post back a copy of the page please and the debug info results
PaulBeta Tester
I added the debug binding to my page and tested again trying to upload an image which would conflict with upload rules, however it is not reporting back anything other than "no file uploaded".
Status object: WA_UploadResult1
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_2:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
My zipped page is attached.
Thanks,
that would mean that the server never received the file.
most likely due to a server setting for post max time or max file size, or another one of the settings that effect uploaded file size.
In order to be able to report that the file does not meet the size restrictions that you set, the server must be able to receive to receive the file, only once the temp file is sent to the server can the server know it's size and reject it or save it based on your settings.
if the server cant accept the uploaded file due to server level restrictions, there is know way for the php processor to implement the restrictions you are setting.
PaulBeta Tester
Ok, so ive set the upload image file limits to
width="620" height="380" in UE4 upload wizard
If i upload an image file with dims width="1024" height="768"
and the file size was under my max limit, what errormessage can i expect to see?
the upload behavior does not have a way of setting file size limits. The setting you are referring to is the resize setting.
Once uploaded, the file will be resized by the server to the 620x380 size you specify.
the problem is that the upload is not completing. The upload status is 0. When the status is 0, none of the other variables will be set because there was no file uploaded for them to get values from.
try turning on error reporting, it may be that a php error is occurring:
error_reporting
(E_ALL);
one issue i see on your p[age is that you have named both the form and the file tag "PropPic". you should always use unique names.
another thing to try that may help us determine the problem is to add a var_dump of the files collection:
echo("<pre>");
var_dump($_FILES);
echo(
"</pre>");
this may tell us what is going wrong.
