Show Region Access Rule
Thread begun 9/08/2012 6:13 am by Paul | Last modified 9/10/2012 8:02 am by Jason Byrnes | 2118 views | 1 replies |
PaulBeta Tester
Been failing miserably to setup a Show Region using SA's access rules.
I have a repeating table populating with 2 or more records each containing a single image.
I have a button assigned to each image against which i wish to apply a show region rule.
I have one condition, where the 'value' and 'compare to' values are taken from two recordsets.
When executed...
Whilst both values do not match, I want to use the rule to show a region.
I want the rule to hide the same region, if the values match
Currently, the rule is not showing my target reqion for all records, which is not the expected result.
I know for sure which record I'll get a match as the variables in my condition are returning the same value from the recordset
Attached is the rule manager screenshot, plus the page taken from.
Any ideas where im going wrong please?
Thank you. Paul.
the security assist show region tool and access rules cannot used for this purpose.
you will need to hand code this condition on your page.
<?php if($row_ShowMyPics['hopicsidx'] != $row_GetPrimaryPhoto['hoprimePhotoID']) { ?>
They don't match
<?php } else { ?>
They Do Match
PaulBeta Tester
Thanks for the hint.
I also found this freebie useful wto resolve my issue - other WA users maybe interested too
http://www.dmxzone.com/go/3328/php-show-if-recordset-field-condition-is-true/
