Error message and the form isn't working... again.
Thread begun 9/07/2012 2:12 pm by BruceT | Last modified 9/10/2012 8:55 am by Jason Byrnes | 1820 views | 3 replies |
BruceT
I've gotten CSS Form Builder to work several times. But then I'll have a problem with a different WebAssist product and when I do the uninstall and reinstall of the other product... in this case the other product was Design Extender... I start getting error messages from CSS Form Builder again! This has happened several times. Does anyone know how to get all the WebAssist programs to play well together?
The error message is attached.
What other extensions are you using?
It sounds like you have a mix of stand alone extensions and Newer Bundled extensions (Design Extender). Make sure that you are not installing any extensions that are bundled into design Extender, refer to the following list:
-- CSS Sculptor
-- CSS Menu Writer
-- Framework Builder
-- PowerCMS Builder
-- Pro Maps for Google
-- Site Import
-- Site Sculptor
-- Social Media Toolkit
and that you don't install any of the stand alone extensions after installing Design Extender.
BruceT
I've done what I was instructed to do... several times
The WebAssist extensions I have installed at the moment are: CSS Button Styler, Security Assist, Theme-It, Free Tools, CSS Form Builder, Design Extender, and eCart... in that order.
I was very careful to uninstall everything I was told to uninstall AND delete the MacFileCache.dat file before installing each program and relaunching Dreamweaver. I've downloaded all the latest versions, so that's not the issue.
If I install CSS Form Builder last, it works just fine but some of the Free Tools programs like Palette Picker stop working. If I install Free Tools last, all of those programs work just fine but I start getting error messages when I try to use CSS Form Builder.
I've tried the uninstall and reinstall routine with either CSS Form Builder of Free Tools as the last installation and I get the same results every time.
