Images won't display / disappear
Thread begun 9/07/2012 11:03 am by DAOS | Last modified 9/07/2012 11:19 am by Jason Byrnes | 2981 views | 1 replies |
DAOS
I use the single image upload. Some images display, some show a broken link image. The same image will display fine in other galleries. Some images that were displaying fine suddenly stop displaying. What am I doing wrong?
I'm using the latest version of PowerGallery2.
This happens in pg and on the webpage and not necessarily the same on both...an example below:
celebrity.php
kari_trescott442964
I am having this same issue - was there a fix you can share?
This usually happens as a result of file permissions issues.
to fix the problem, make sure that all files and folders under the /galleries folder are set to 755 permissions, you can do this in most FTP clients like filezilla by right clicking on the webassist folder in the file panel and selecting the Set File Permissions option, setting the 755 permission level then selecting the option to apply this to "Recurs into subdirectories" -> "Apply to all files and directories"
Also, edit the admin_gallery/common/properties.php file, change the following code:
$GLOBALS['permissions'] = array(
'dir' => 0777,
'file' => 0666
'dir' => 0755,
'file' => 0755
Rune Brynestad
Same problem for me. I have some galleries created. The first 2 looks ok, but the next 2 does not.
All files and folders under the /galleries folder are set to 755 permissions.
the admin_gallery/common/properties.php file is changed to
'dir' => 0755,
'file' => 0755
I'm attaching some screenshots to illustrate my problem:
Regards
Rune
