postage not working on "live" site
Thread begun 9/07/2012 8:24 am by WhiteJC | Last modified 9/11/2012 7:57 am by Jason Byrnes | 3962 views | 7 replies |
WhiteJC
I've setup a post and pack charge to be £4 for 1/2 kilo and under and £6 for over 1/2 kilo.
It works on my testing server however on the "live" site it always charges £6?
I figure I must have made some changes to the test system? what files do I need to ensure their copied over to the live system, I'm assuming the error is with an old version of the p&p code?
make sure the files in the WA_eCart folder are uploaded to the server.
WhiteJC
Hi Jason
I've copied over the WA_eCart folder, just to make sure I deleted the folder on the "live" system and then copied the folder to make sure I've got the correct folder and I still get the same results, any ideas?
post a link where i can see the problem and a screen shot of the shipping rules settings please.
WhiteJC
Hi Jason
the "live" version can be found here...
PRODUCTdetail.php?id=7&sku=F
however, "buying" this item, you'll need to select from 2 drop-down lists, choose the first item(s) from both lists.
when you need to sign-in, to "buy" the item use this username and password
john.cummins@mccarthy-design.com
yesterday
(I'll change the password after you've used it)
"tick: the T&Cs, select credit card, same billing address address (use UK mainland) from the drop down.
you'll see the Shipping on the confirmation page, it should be £4 but its £6
the shipping charge is generated from session (ShipCharge) which in turn is generated from a database look-up
this is the shipping rule:
if session variable exists: ShipCharge
create a flat rate shipping of $ $_SESSION['ShipCharge']
here's the database look-up
SELECT *
FROM ship_rate
WHERE shipWEIGHT >= colname AND ship_rate.shipZONE = zZONE
ORDER BY shipZONE ASC , ship_rate.shipWEIGHT DESC
colname = $_SESSION['zoneWEIGHT']
zZONE = $_SESSION['zoneNUMBER']
the WEIGHT & NUMBER donate the combined product(s) weight and the number is a zone reference, different zones charge different amounts (mainly due to distance)
to help troubleshot, add the following code on the PAYconfirm.php page just before the </body> tag:
<pre><?php var_dump($_SESSION); ?></pre>
this will allow me to see the contents of the session.
WhiteJC
Hi Jason
this is a "live" site, can you look at the page at a specific time, then I can return the page to "normal" and not effect any customers?
I'm based in the UK so I think I'm 5 hours? ahead of you, give me a time to upload the amended page and I'll make sure its done
rgds
John
i am on the East coast in america, I am EST. It is currently 10:56am. How about 11:30am? let me know if that works
