Launching DataBridge Dialog Disappears
Thread begun 9/06/2012 9:49 am by dlovas275157 | Last modified 12/01/2014 9:27 am by Jason Byrnes | 1679 views | 3 replies |
dlovas275157
I have just purchased and installed SuperSuite. I have activated everything with the proper serials.
Problem: If I choose any WebAssist extension item from the menus from within Dreameaver, the dialog window comes up for a second, but then disappears. As a result, I cannot use any extension.
I am using:
Mac OSX 10.6.8
Dreamweaver CS 5.5
Latest SuperSuite
**I am behind a corporate firewall - could this cause this issue?
Please advise how to fix this issue. I have already tried re-installing everything, and dumping the MacCache File a few times.
-Daniel
Suggs
Im having the same issues
I too am having this issue... can anyone advise on the fix? I have updated to all the latest versions.
Mac versions 10.9.5 and running Dreamweaver CS6
Normally, this happens if the web assist installer does not run to complete the installation.
Close DW, then open the extension manager.
In the extension manager, uninstall the extensions, then install them again.
When you open DW, it should launch the web assist installer. If the WA Installer does not launch, open a php page to force it to start.
After the WebAssist installer completes, make sure to restart DW.
