Tax After Discount
Thread begun 9/05/2012 11:17 pm by Lee Firth | Last modified 9/11/2012 2:16 pm by Lee Firth | 4338 views | 8 replies |
Lee Firth
Tax After Discount
I want to add 10% GST tax to the sub total of the cart after discount. I used the charges tab of the eCart object and set it up to the cart subtotal * 0.1 and checked the "apply after Discounts" checkbox (see gst_1.gif). The calculations are all wrong on the confirm.php page (see gst_2.jpg). The GST charge in this example should be $72.73 - $18.18 * 0.1 which should equal $5.45. I thought that it may have been including the shipping in the calculation (that would have been $6.82 if it was) but I have the checkbox "Include in cart subtotal when calculating sales tax" deselected.
One thing I did notice is that the "apply after Discounts" checkbox on the eCart objects Charges tab doesn't save, that is if you go back into that tab again, you have to select the checkbox again.
It looks like you have edited the cart display for the subtatol line.
the actual subtotal in the cart is $80.00, not the $72.73 that is shown
so the charge is being done as:
80 - 18.18 * 0.1 = 6.18
Lee Firth
OK, had to manually edit the tax rule (couldn't use the GUI) and now the GST displays the correct amount. But now the Grand Total doesn't calculate correctly (see cart_3.jpg attached). I can't find where this is calculated.
the grand total is calculated in the cart.
instead of hand coding things to remove the VAT from the cart display, you should create a discount that will do that inside the cart that way the cart will handle the total correctly and you wont need to do any hand coding of the cart display.
Lee Firth
I don't understand what you mean. The discount is calculated inside the cart.
in your screen shoot, the subtotal shows $72.73 but the item costs $80
what ever hand coding you doing to cause that is what i am referring to.
you should not be hand coding the sub total to change it.
Lee Firth
Both of these figures are calculations within the cart itself. The $80 value is a calculation including GST (TotalPrice). The client wanted all prices on their website to be displayed including %10 GST, as GST is only applicable to Australian residents I have to remove it in the subtotal (SubTotal)and then add it at the end for Australian residents only. See calculations.jpg attached.
that info would have helped a lot up front.
I have a feeling the issue is in naming the calculation SubTotal, but i'll need to do some testing.
can you send a copy of the cart display page and the eCart object file from the WA_eCart folder please.
Lee Firth
Sorry about that Jason. The files are attached. I have managed to get it to calculate correctly but this involved changing the GetTaxableTotal() function in WA_eCart_Definition_PHP.php from:
function GetTaxableTotal() {
    $taxTotal  = 0;
    $taxTotal  = $this->TotalColumn("TotalPrice");
    $taxTotal -= $this->GetDiscounts();
    $taxTotal += $this->GetCharges();
    if ($this->ShippingIsTaxed) {
      $taxTotal += $this->GetShipping();
    return $taxTotal;
To:
    $taxTotal  = 0;
    $taxTotal  = $this->TotalColumn("SubTotal");
    return $taxTotal;
I don't think it is advisable to do it this way so I would really appreciate you looking at the attached files and letting me know the correct way I should be using.
Use the Same calculation for TotalPrice that you are using for SubTotal, right now, they are a little different.
