Transaction ID
Thread begun 9/05/2012 3:09 pm by Cologne | Last modified 9/06/2012 12:51 pm by Jason Byrnes | 1617 views | 3 replies |
Cologne
Transaction ID
Hello,
how do I get the Transaction ID
<?php echo WA_PP_ECO_GetValue($WA_PP_ECO_DoResult, "TransactionID"); ?>
in the success page?
When I use the Binding it shows nothing :-(
Cheers,
Denis
Yes, that should show the transaction ID, if it is not showing a value, it is most likely a failed transaction.
Add the full request and full response bindings to your page to see the full details going to and coming back from the gateway.
Cologne
Hello Jason,
There only comes a result, if I use it on the confirm page where the prosess transaction behavior is.
But how can I get it on the success page, where only the get payer profile behavior is.
I need to check if the user did a donation and not only opens the success page.
Maybe I can use the TOKEN, but is it safe to use?
Any suggestion how I can check the did a donation?
Cheers,
Denis
on the confirm page, use the set session value behavior to save the transaction ID to a session variable, the session variable will be available to the success page.
