Subtract
Thread begun 9/05/2012 3:00 pm by Cologne | Last modified 9/11/2012 3:00 pm by Cologne | 7595 views | 12 replies |
Cologne
Subtract
can someone help me to subtract this two echos?
<?php echo WA_PP_ECO_GetValue($WA_PP_ECO_DoResult, "GrossAmount"); ?>
<?php echo WA_PP_ECO_GetValue($WA_PP_ECO_DoResult, "FeeAmount"); ?>
I tried this,
<?php echo WA_PP_ECO_GetValue($WA_PP_ECO_DoResult, "GrossAmount") - WA_PP_ECO_GetValue($WA_PP_ECO_DoResult, "FeeAmount"); ?>
but this does not work :-(
Cheers,
Denis
that code looks correct, it should work if there is a valid result coming back from paypal after the transaction has been successfully processed.
These values will be available to the checkout success page.
Cologne
Hi Jason,
This does not work, it always says, column donation cant be null.
if I take only one of em it works.
very strange.
ps. I use it in the confirm page, where the wizzard uses the database input, too.
Cheers,
Denis
send a copy of the page please.
Cologne
here it is
the folder SEPNDE is in the root.
startingpoint is spende.php
Cologne
did i add the file?
here it is
to help troubleshoot, find the following code on the success page at lines 136 - 137:
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
  $MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
and change it to:
die("SQL: ".$WA_Sql );
this will write the insert query to the screen
Cologne
I did
SQL: INSERT INTO `donation` (`token`,`transaction_id`,`donor_email`,`donationGross`,`donationFee`,`donation`,`original_request`) VALUES ('EC-23L39107G8551950R','0YJ77963BF348464J','buyer_1298809119_per@denis-online.de',20,1.13,0,'buttonConfirm=Jetzt+SPENDEN%21')
so, it does not substract
20 - 1.13
thats what does not work.
now I tried
<?php echo WA_PP_ECO_GetValue($WA_PP_ECO_DoResult, "GrossAmount"); ?> - <?php echo WA_PP_ECO_GetValue($WA_PP_ECO_DoResult, "FeeAmount"); ?>
too.
nothing works.
Denis
Cologne
lol,
<?php echo (WA_PP_ECO_GetValue($WA_PP_ECO_DoResult, "GrossAmount") - WA_PP_ECO_GetValue($WA_PP_ECO_DoResult, "FeeAmount")); ?>
In the confirm page you sent, you aren't using that code, the confirm page you sent is using this instead:
$mhqFee = WA_PP_ECO_GetValue($WA_PP_ECO_DoResult, "FeeAmount");
$mhqGross = WA_PP_ECO_GetValue($WA_PP_ECO_DoResult, "GrossAmount");
$mhqDonation = $mhqGross - $mhqFee;
I'm confused. the code you say you are using and the code in your pages is not matching, making it very difficult to tell what you are doing wrong.
