Problems with the sort function
Thread begun 9/05/2012 1:37 am by Noa2086 | Last modified 9/07/2012 8:14 am by Noa2086 | 2068 views | 2 replies |
Noa2086
i would like to sort my records by date. in europe we have this format: dd/mm/yyyy.
the situation is: it starts with day, then month, then year. i would like to start with year, then month, then day. All DESC.
why does my validation for spry not work?
thx for your quick help!
Willi Schneider
For your first problem:
What's the column type for the date entries?
I guess you have set it to "varchar" or something like that.
You should set it to "date" and insert the values like "yyyy-mm-dd".
In your portfolio page (=results table) you have to convert the date form "yyyy-mm-dd" to display like "dd.mm.yyyy".
You can do this in the bindings panel in dreamweaver --> select the date column and change the date format to "MySQL Date/Time: 30.12.2002"
There's a free dreamweaver extension at document.php?id_doc=51 which can do all the needed conversions.
Then you sort your recordset according to your wishes.
Your second problem:
the page shows a javascript error:
Meldung: 'Spry' ist undefiniert
Zeile: 291
Zeichen: 5
Code: 0
URI: kontakt.php?invalid=true
So maybe, that's the reason for the validation to fail. Just a guess however.
Noa2086
thx willi for your answer!
i changed it to date.
i have cs6 and can't see any format button in the bindings panel.
the validation tooltips for spry thing: i builded it up from zero. now its working. very annoying.
how can i set a default value to input files? is there a smart way to style it?
my datepicker does not work. any ideas? i have a custom theme with jquery.
files included:
2 jquery and 1 css
thx for your help!
Noa2086
my solution to format from yyyy-mm-dd to dd-mm-yyyy:
if the record is empty => show "no data"
<?php if ($row_Services['Datum'] != "") {
$originalDate = $row_Services['Datum'];
$newDate = date("d.m.Y", strtotime($originalDate));
echo $newDate;
} else { echo 'Kein Eintrag'; } ?>
=> "Services" is my recordset
=> "Datum" is my field name
=> "Kein Eintrag" is german and means no data.
