Methods for building dynamic filter searching
Thread begun 9/04/2012 8:46 am by alnico431299 | Last modified 9/07/2012 11:00 am by alnico431299 | 7060 views | 6 replies |
alnico431299
I am investigating methods for building dynamic filter searching such as Zappos, Amazon (I guess they call these faceted searches) with php/mysql.
Scenario:
1. I have a list of search parameters (checkbox’s, radio’s, etc), that belong to filterForm. A search query would be built by adding or subtracting parameters as they are selected and query the server upon each selection.
2. I also need to get the count of hit/matches for each parameter in the filterForm, regardless if they are selected or not.
So essentially, I need to query for matches and return a dataSet AND simultaneously get each parameter count for the active dataSet.
Method’s:
1. Request two separate queries in succession, I believe this is wasteful and prone to inaccurate counts?
2. Use a Stored Procedure (capable of returning two dataSets from same Select)?
3. Request match dataset and create session variable containing array of parameter/counts?
4. Use php to split the dataset into two?
These are just ideas; I am not sure what is at all possible here…
Looking for direction, suggestions and how this may be tied into DataAssist; if at all?
Thanks,
Brent
This can be done using Data Assist Search to create the search form.
you first create a results page that is unfiltered, then run the data assist search wizard to create the search form. the search wont take place as conditions are selected though, the form would need to be submitted manually for the flittering to occur.
alnico431299
Creating a search form with results page is not the issue here, that is pretty straight forward.
Upon selecting each filter...I would submit the form using jquery, not to difficult either.
The issue is getting the record count for all filters based on the returned recordset; all in a single operation; without having to fire off two repetitive (wasteful) queries (one for the results page and the other, filter counts; both share a large part of the same query).
Here is an example...
database table: worldFlags
1 America
2 Britain
3 Canada
Filters (initial state):
Red (0)
White (0)
Blue (0)
Green (0)
Filters (state after selecting Blue):
Red (3)
White (3)
Blue (2)
Green (0)
Records returned matching Blue:
1 America
2 Britain
Each time a filter is selected it must return two sets of information...the Records that match the query and the counts for that recordset.
So, back in my original post I describe some methods that could be used???
Hopefully you understand what I am trying to accomplish ;-)
the basic dreamweaver pagination that is added to the results page will show a total count.
something like "Showing record 1 - 10 of 248" this is a basic function of the Dreamweaver paging controls.
alnico431299
Jason...that is not at all what I am trying to achieve here.
Perhaps this is to difficult to explain in writing. All I can add is that I am building a multi-faceted(checkboxes) search where you can drill down on a recordset dynamically via checkboxes...which returns a results page AND match counts for EACH facet(checkbox).
This essentially gives me my matches I searched for and also I am able to see each checkbox with a match count behind it; if the count is zero I will know that I am not able to drill down on the recordset further...alternatively other checkboxes may have a count greater than zero, where I may continue to drill down.
So again, I am looking for methods as explained in my first post.
Here is a tutorial i found through google that uses Sphinx to do something similar to what i think you are talking about:
faceted-search-with-sphinx/
alnico431299
Yep, I have Googled and found many docs including the one you mentioned...the setup is overly complex for what I need (I do not need full text search, etc).
This is a very common search method and can be complex to setup.
Thanks,
Brent
