Place holder visibility
Thread begun 9/04/2012 12:03 am by savvy1297305 | Last modified 9/05/2012 5:26 pm by savvy1297305 | 1907 views | 4 replies |
savvy1297305
When I place a like button inside a div on a static html page I cant see the place holder on the page nor the css for it in the styles panel therfore I cant edit it apart from in the code.
If I place the button on a plain html page (no div) I can see the place holder but no css. This is all in design view of course. The like button shows up when I test in a browser both ways all good.
How can I have the place holder be visible in the div in the html page?
set the class of the div to wasocial_facebook_like
savvy1297305
Hi Jason,
That is how it is set by the extension here is the code which I have put inside a dive which is nested in otter divs. If I take it out of the div no change.
<div id="facebook_contact">
<div class="wasocial_facebook_like">
<div id="fb-root"></div>
<script src="http://connect.facebook.net/en_US/all.js#xfbml=1"></script>
<fb:like href="http://localhost/water_bottles_online/" send="false" layout="standard" width="300" show_faces="false" action="like" colorscheme="light" font="verdana"></fb:like>
</div>
</div>
the style applied to your div is over riding the style of the like button div.
doesthe div you have the like button in have a class applied to it?
if not, use the same class that the like button div uses
savvy1297305
I am a newbie to this but the way I see the code the class is already there ? (second line) This problem exists no matter where in the page I put the like button unless I place it outside the #wrapper - If I have it wron and I think I do if you could direct me as to what and wher it needs to go that would be good - thanks in advance
