"Config info invalid for wagmp_map.htm" +
Thread begun 9/03/2012 10:46 pm by simon433077 | Last modified 9/05/2012 8:13 am by simon433077 | 1935 views | 2 replies |
simon433077
Brand new installation of DW 6, brand new download tonight of latest versions of eCart, DesignExtender, DataBridge and FreeTools, successfully installed eCart, after installation of DesignExtender, close Extension Mgr, close DW, and get following message:
"The following translation was not loaded due to errors; wagmp_map.htm has configuration information that is invalid."
Then, same message for wagmp_map_directions.htm.
Message repeats 9 or 10 times before letting me close DW and restart.
Should I continue with installing DataBridge and FreeTools or should I fix these errors? And how do I fix them anyway? Very clean installation, no other extensions loaded. This is the Adobe CS 6 package with DW, Fireworks, Flash, Illustrator 32 and 64, Indesign and Photoshop 32 and 64, running on a 64-bit Vista computer with 6 GB ram.
And does your Image Verification really not work on FF or Chrome, or are my popup blockers causing this problem...if so, why are they popups? Not good, taking me three different submits to solve this problem that I should not have in the first place!
"close Extension Mgr, close DW, and get following message:"
Dreamweaver should not be opened while installing extensions.
When you are installing extensions, only the extension manager should be opened.
close Dreamweaver, then Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
simon433077
Doh...thanks. Never remember that, about not having DW open with Extension Mgr. Thanks, all installations went in fine (except for all the "an older version" and/or "a newer version" alerts, expecially when installing Free Tools, but I assume there will not be any problems with these 4 installls, since they are all the latest versions.)
