eCart Recordsets
Thread begun 8/29/2012 2:36 pm by Loretta439108 | Last modified 8/31/2012 8:06 am by Jason Byrnes | 3439 views | 6 replies |
Loretta439108
eCart Recordsets
Hello,
I'm selling a product that has various sizes with corresponding prices (not incremented) and I'm having difficulty coordinating the recordsets, add to cart behaviors and pull down menus.
I have three tables - an item table, a linking itemoptions table and an options table that has the sizes, prices and weights in it.
I can't seem to get my add to cart buttons to add anything to my cart page. Any help would be greatly appreciated!
Here's the code:
//WA eCart Include
require_once("WA_eCart/CarteBlank_PHP.php");
<?php require_once('Connections/connSpectrum.php'); ?>
$CarteBlank->GetContent();
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_connSpectrum, $connSpectrum);
$query_rsItems = "SELECT ItemID, ItemCatID, ItemName, ItemDesc, ItemSKU, ItemImage FROM items ORDER BY ItemID ASC";
$rsItems = mysql_query($query_rsItems, $connSpectrum) or die(mysql_error());
$row_rsItems = mysql_fetch_assoc($rsItems);
$totalRows_rsItems = mysql_num_rows($rsItems);
<head>
<title>Product Page</title>
<link href="css/global.css" rel="stylesheet" type="text/css" />
</head>
<body background="img/metgrad.jpg">
<div id="container">
<div id="banner">
<p><img src="img/header2.gif" alt="W" width="950" height="141" longdesc="http://www.fff.com/" /></p>
</div>
<?php do { ?>
$varItem_rsSizes = "1";
if (isset($row_rsItems['ItemID'])) {
$varItem_rsSizes = $row_rsItems['ItemID'];
$query_rsSizes = sprintf("SELECT items.ItemID, options.OptionID, options.Option, options.OptionPrice, options.OptionWeight FROM items LEFT OUTER JOIN itemoptions ON items.ItemID = itemoptions.ItemID INNER JOIN options ON itemoptions.OptionID = options.OptionID WHERE items.ItemID = %s", GetSQLValueString($varItem_rsSizes, "int"));
$rsSizes = mysql_query($query_rsSizes, $connSpectrum) or die(mysql_error());
$row_rsSizes = mysql_fetch_assoc($rsSizes);
$totalRows_rsSizes = mysql_num_rows($rsSizes);
$paramOption_rsSizeLookup = "-1";
if (isset($_POST['eCarteBlank_1_size_Add'])) {
$paramOption_rsSizeLookup = $_POST['eCarteBlank_1_size_Add'];
$paramItem_rsSizeLookup = "-1";
if (isset($_POST['eCarteBlank_1_ID_Add'])) {
$paramItem_rsSizeLookup = $_POST['eCarteBlank_1_ID_Add'];
$query_rsSizeLookup = sprintf("SELECT options.OptionID, options.`Option`, options.OptionPrice, options.OptionWeight, itemoptions.ItemOptionID FROM options INNER JOIN itemoptions ON options.OptionID = itemoptions.OptionID WHERE itemoptions.OptionID = %s AND itemoptions.OptionID = %s", GetSQLValueString($paramOption_rsSizeLookup, "int"),GetSQLValueString($paramItem_rsSizeLookup, "int"));
$rsSizeLookup = mysql_query($query_rsSizeLookup, $connSpectrum) or die(mysql_error());
$row_rsSizeLookup = mysql_fetch_assoc($rsSizeLookup);
$totalRows_rsSizeLookup = mysql_num_rows($rsSizeLookup);
// WA eCart AddToCart
if (isset($_POST["CarteBlank_1_ATC"]) || isset($_POST["CarteBlank_1_ATC_x"])) {
$ATC_itemID = $_POST["CarteBlank_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "";
$ATC_RedirectIfIn = "";
if (isset($totalRows_rsItems) && $totalRows_rsItems > 0) {
$row_rsItems = WAEC_findRecordMySQL($rsItems, "ItemID", $ATC_itemID);
if ($row_rsItems) {
$ATC_itemName = "".$row_rsItems['ItemName'] ."";// column binding
$ATC_itemDescription = "".$row_rsItems['ItemDesc'] ."";// column binding
$ATC_itemThumbnail = "img/small/".$row_rsItems['ItemImage'] ."";// column binding
$ATC_itemWeight = floatval("".$row_rsSizeLookup['OptionWeight'] ."");// column binding
$ATC_itemQuantity = "".$_POST["CarteBlank_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_rsSizeLookup['OptionPrice'] ."");// column binding
$ATC_itemSize = "".$row_rsSizeLookup['Option'] ."";// column binding
$ATC_itemSKU = "".$row_rsItems['ItemSKU'] ."";// column binding
mysql_data_seek($rsItems, 0);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$CarteBlank->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemSize, $ATC_itemSKU);
if ($ATC_RedirectAfter != "" && $CarteBlank->redirStr == "") {
$CarteBlank->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($CarteBlank->redirStr != "") {
header("Location: ".$CarteBlank->redirStr);
<div class="ul">
<p><?php echo $row_rsItems['ItemName']; ?></p>
<p><?php echo $row_rsItems['ItemDesc']; ?></p>
<p><?php echo $row_rsItems['ItemSKU']; ?></p>
<p><img src="img/small/<?php echo $row_rsItems['ItemImage']; ?>" alt="image" /></p>
<p>&nbsp;<form name="CarteBlank_1_ATC_<?php echo $row_rsItems["ItemID"]; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<p>
<input type="hidden" name="CarteBlank_1_ID_Add" value="<?php echo $row_rsItems["ItemID"]; ?>" >
<input type="text" name="CarteBlank_1_Quantity_Add" value="1" size="4" >
<label for="eCarteBlank_1_size_Add">Sizes & Prices</label>
<select name="eCarteBlank_1_size_Add" id="eCarteBlank_1_size_Add">
do {
<option value="<?php echo $row_rsSizes['ItemID']?>"><?php echo $row_rsSizes['Option']?>&nbsp; &nbsp;$<?php echo $row_rsSizes['OptionPrice']?></option>
} while ($row_rsSizes = mysql_fetch_assoc($rsSizes));
$rows = mysql_num_rows($rsSizes);
if($rows > 0) {
mysql_data_seek($rsSizes, 0);
</select>
</p>
<p>
<input type="image" src="img/PNG/addtocart.png" border="0" class="eC_ImageButton" value="Add to Cart" name="CarteBlank_1_ATC">
</p>
</form>
</p>
<p>&nbsp;</p>
</div>
<?php } while ($row_rsItems = mysql_fetch_assoc($rsItems)); ?>
</div>
</body>
</html>
mysql_free_result($rsItems);
mysql_free_result($rsSizes);
mysql_free_result($rsSizeLookup);
Thanks!
you have the code for the add to cart button behavior code inside of a loop, this is why it is not working.
the add to cart button behavior code should be in the head of the page.
Loretta439108
Thanks so much! eCart had automatically inserted the code after the rsSizes recordset that was in the loop.
The add to cart button works now except that the values for the weight, size and price are all 0. Are my recordsets the problem, or is there something else that I'm missing?
Here's the revised code:
//WA eCart Include
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "cart.php";
if ($row_rsItems) {
else {
<head>
</head>
<div id="banner">
<p><img src="img/header2.gif" alt="" width="950" height="141" longdesc="http://www.fff.com/" /></p>
</div>
<?php do { ?>
<div class="ul">
<p>
do {
if($rows > 0) {
</select>
</p>
<p>
</p>
</form>
</p>
<p>&nbsp;</p>
</div>
<!-- An associative fetch array-which returns one row of date
at a time, in an array format -->
</div>
</body>
</html>
Thanks much, I'm grateful for your help.
Loretta439108
Actually the size is blank and the price, weight and total are 0.00.
the option select list value should use the OptionID column instead of ItemID
the size lookup recordset, you the where clause using the itemoptions.OptionID twice
WHERE itemoptions.OptionID = paramOption AND itemoptions.OptionID = paramItem
it should be:
WHERE itemoptions.OptionID = paramOption AND itemoptions.ItemID = paramItem
Loretta439108
Hello,
I changed the option select list value to OptionID.
When I attempt to edit the rsLookup recordset I get the following error message: "While executing applyServerBehavior in Recordset.htm, a JavaScript error occurred."
I edited the code manually and changed the WHERE clause, but I'm still getting no size in the cart and the weight, price and total are 0's.
Thanks again...
