Joining tables in Update page for Databridge
Thread begun 8/29/2012 6:15 am by Patrice | Last modified 9/11/2012 2:19 pm by Patrice | 6884 views | 24 replies |
PatriceWebAssist
I'm starting a new project and trying to think through how to get it done properly.
Scenario:
Client has several employees who perform timed tasks, ie, at 8 am, they sign into work, by 9 am a set of tasks need to be completed, etc.
I know at some point I'll need to revisit Security Assist for individual employee login, but I'm not that far along in my work yet. I used SA a few years ago for a membership site, so I'll need to dust off my notes to learn how to do it again.
So at this stage, I have created these tables:
Projects (project_ID, project_name)
Tasks (task_ID, task_name, task_starttime, project_ID, employee_ID, task_competion -using a timedate stamp)
Employees (employee_ID, employee_name, employee_email, employee_password)
So, the employer will create the Project, assign tasks to that project, and an employee.
What I need then, is an employee Update page that will present fields so a particular employee can check a box when a task is completed. So that Update page will need to join all three tables together. I know how to create the page that presents three tables for the employer, but not yet sure how to make the update page for the employee. Can more than one table be used in an Update page? Any tutorials for doing this?
Thanks to anyone who has time to read and respond.
PatriceWebAssist
I just found this:
data_bridge_manage_relational_table.php
It might be what I'm trying to understand.
PatriceWebAssist
Well, if I could get by step 4 of getting the sql onto my server....
phpMyAdmin isn't letting me import for some reason. Maybe step 3 Open your Mysql database manager means something other than phpMyAdmin.
try opening the SQL file in a text editor, copy all the SQL, then in PHPMyadmin go to the SQL tab, and past the SQL to run it.
you may need to create the blue_sky_music data base manually and make sure it is selected, and remove this from the SQL:
CREATE DATABASE IF NOT EXISTS blue_sky_music;
USE blue_sky_music;
PatriceWebAssist
Thank you! That worked. Thanks Jason.
PatriceWebAssist
Working my way thru that tut. Found a typo that is important for making it work.
I printed it out so using that, the error is on page 5 of 20.
Top section of page, step 5: Enter rsGeneres as the name of the recordset.... which is fine except lower on the page, it calls for rsGenres --- so the name of the record set isn't going to match your instruction of hand coding php echo row etc..
I discovered this because I used the bindings to pull in the echo instead of trying to type it in...
HTH someone.
PatriceWebAssist
Originally Said By: Patrice
Scenario:
Am I missing a joining table in my concept? While the tut is fine, I've not worked all the way thru and am getting frustrated. I want to jump into my own situation and see what I can do.
In your concept, the Tasks table is the linking table:
The project_ID columns creates a many to many relation for the main table Projects.project_ID column
and the employee_ID column creates a many to many relation for the option table Employees.employee_ID
NOTE: While it is entirely up to you, It's a good idea to use a naming convention for your columns that prevents duplicate names. also, using underscores in the column names can cause issues in Dreamweaver, I prefer and recommend to use the camelCase naming convention instead.
The naming convention i like to use is to include the table name as a prefix to the column names. you are pretty much already doing this, with the exception of the foreign key columns in the tasks table. For example, the naming convention I would use for your tables is;
projects (projectID, projectName)
tasks (taskID, taskName, taskStarttime, taskProjectID, taskEmployeeID, taskCompletion)
employees (employeeID, employeeName, employeeEmail, employeePassword)
by using taskProjectID and taskEmployeeID as the name in the tasks table, there is no way to confuse them with the projects.projectID or employees.employeeID primary key columns. this can helpful when working with a big recordset that joins many tables together.
PatriceWebAssist
Thank you Jason! I really appreciate the advice. I didn't know about underscores and DW. And I thought the foreign keys in a table had to match the originals. No wonder some databases have been confusing me!
Really appreciate the help.
PatriceWebAssist
Update and puzzled.
Again, thank you Jason for all the advice.
I've recreated the 3 tables with the naming system you advised. I've entered some data so I can test further.
But I'm stuck again.
The way I have it up to this date, the employer would have to go in and create a set of tasks for each day of the year before the employee could check off that it was completed on time or not.
I added a projectDate field so that a task can be assigned to a date. But that doesn't solve labor intensive issue of employer adding 5 tasks each day to 5 employees. That will never work.
Any guidance most appreciated.
