Date format issues
Thread began 8/28/2012 10:56 pm by keith298718 | Last modified 8/30/2012 7:56 am by Jason Byrnes | 1166 views | 3 replies |
keith298718
Date format issues
Hi
I have 2 pages an insert and a results page both generated with data assist wizard. The date picker on the insert page only works when the format is set to mm,dd,yy. I need it to display as dd,mm,yy. I have tried
$(function(){
$('#jdate').datepicker({
changeMonth: true,
changeYear: true,
dateFormat: 'dd-mm-y',
onClose: closeDatePicker_jdate
But that does not effect the display of the date, I have also tried setting the format in datepicker to dd,mm,yy but this gets an error when trying to insert the record , I have tried editing the insert code
"Customer|Job|Parts_Required|Issues|Location|Tech|Contact|Priority|jdate";
$WA_fieldValuesStr = "".((isset($_POST["Customer"]))?$_POST["Customer"]:"") ."" . $WA_AB_Split . "".((isset($_POST["Job"]))?$_POST["Job"]:"") ."" . $WA_AB_Split . "".((isset($_POST["Parts_Required"]))?$_POST["Parts_Required"]:"") ."" . $WA_AB_Split . "".((isset($_POST["Issues"]))?$_POST["Issues"]:"") ."" . $WA_AB_Split . "".((isset($_POST["Location"]))?$_POST["Location"]:"") ."" . $WA_AB_Split . "".((isset($_POST["Tech"]))?$_POST["Tech"]:"") ."" . $WA_AB_Split . "".((isset($_POST["Contact"]))?$_POST["Contact"]:"") ."" . $WA_AB_Split . "".((isset($_POST["Priority"]))?$_POST["Priority"]:"") ."" . $WA_AB_Split . "".((isset($_POST["jdate"]) && $_POST["jdate"]!="" )?date("Y-m-d H:i:s", strtotime($_POST["jdate"])):"") ."";
But again no success
Its been a while since I have done any web dev work so I am probably missing something very obvious
Please see attached file for full code
Keith
agtronics.zip
there are 2 pieces of code on the insert page that effect the way the date is displayed:
$(function(){
$('#datepicker_1').datepicker({
dateFormat: 'mm/dd/yy',
showAnim: 'show',
onClose: closeDatePicker_datepicker_1
var jdate_Spry = new Spry.Widget.ValidationTextField("jdate_Spry", "date", {isRequired: false, format:'mm/dd/yyyy', validateOn:["blur"]});
the format needs to be changed in both places.
to use the dd-mm-yyyy format, change those 2 pieces of code to:
$(function(){
dateFormat: 'dd-mm-yy',
showAnim: 'show',
var jdate_Spry = new Spry.Widget.ValidationTextField("jdate_Spry", "date", {isRequired: false, format:'dd-mm-yyyy', validateOn:["blur"]});
you will also want to change the following code on the resuklts page to change the way it shows there:
<?php echo(($row_WADAcurrent_jobs['jdate'])?date('d/m/Y',strtotime($row_WADAcurrent_jobs['jdate'])):''); ?>
change that to:
<?php echo(($row_WADAcurrent_jobs['jdate'])?date('d-m-Y',strtotime($row_WADAcurrent_jobs['jdate'])):''); ?>
keith298718
insert page still not behaving
I changed the code in the insert page and as soon as you leave the date field you get an invalid format message. The date displays correctly.
I am probably missing something else that's obvious
See attached code
Keith
current_jobs_insert.zip
you change the spry validation format to a 2 digit year.
change:
var jdate_Spry = new Spry.Widget.ValidationTextField("jdate_Spry", "date", {isRequired: false, format:'dd-mm-yy', validateOn:["blur"]});
