pdf builder
Thread began 8/28/2012 8:07 am by asarcona308398 | Last modified 8/28/2012 8:07 am by asarcona308398 | 827 views | 0 replies |
asarcona308398
pdf builder
I was hoping to see some sort pdf builder from webassist!
something that was similar to dompdf, (dompdf/) in the way that it could produce .pdf's from the webpage referenced - on-the-fly!
dompdf is extremely effective but a little cumbersome to use for the non-programmer.
Just puttin it out there!!
gavind
Maybe if added as an option, definitely a +1 here.
arron
Hi, asarcona308398.
Thanks for your nice sharing. And I wonder what does PDF builder do? It helps to
create PDF files, right? As for me, I have ever tried to build PDF files using another PDF building toolkit offered by YG instead of dompdf and the one you mentioned above. But I will check it out due to your nice recommendation. Good luck.
Best regards,
Arron
