Captcha does not work correctly
Thread begun 8/28/2012 3:17 am by Noa2086 | Last modified 8/31/2012 8:58 am by Noa2086 | 4932 views | 9 replies |
Noa2086
i have problems with the captcha function.
1) it shows the servererror message not correctly (i use validation tooltips for spry)
2) it does not check the captcha value entered before i send the form
3) no progress bar, no email message
thx for your quick help
the captcha validation is not a spry validation, the you cannot use Validation tooltips for spry to style the captcha error message, it can only style spry validation errors
Yes, that is the way server validation works, the form needs to be set to the server in order for the server to perform the validation.
if validation fails, it returns you back to the form to correct the problem.
I am seeing the progress bar, but the validation is failing so the email wont be sent, If you need further assistance, send a copy of the page.
Noa2086
hi jason,
thx for your quick help! here is a copy..
don't know how to fix it.
Noa2086
I have another problem with my delete button on my result page..
WadaDeleteRecordID does not work. i cannot get the correct id.
i tried it with:
$WA_fieldValuesStr = "".($row_portfolio['ID']) ."".(isset($_GET["pageNum_portfolio"])?"&pageNum_portfolio=".intval($_GET["pageNum_portfolio"]):"") ."";
it only deletes the first record on the page. any idea?
in the validation you have set the like entry to use the captcha_Security_Code_1 session variable.
it should be using the captcha_Sicherheitsfrage_2 variable instead
Noa2086
hi jason,
i set the variable to captcha_Security_Code_2 but it does not help. i set the session variable to captcha_Security_Code_1.. why 2 at the end?
why can i see the error message?
no email and success page when the answer is right?
you see the error because validation is failing. it is failing because you are not using the correct variable
the session variable to use is not "captcha_Security_Code_2" it is "captcha_Sicherheitsfrage_2"
Noa2086
thx you jason! now it works. but where have you seen a session variable with the name captcha_Sicherheitsfrage_2??
above i asked you how to get the right ID on my result page to delete records. how can i do this?
in the delete button that is in the repeat region:
<input type="button" value="Löschen" class="likebeyondcom" id="DeleteConfirm" name="DeleteConfirm" onClick="document.getElementById('deleteBox').style.display = 'block';document.getElementById('deleteMessage').style.display = 'table';">
add an onlclick event to pass the current ID to the delete message
<input type="button" value="Löschen" class="likebeyondcom" id="DeleteConfirm" name="DeleteConfirm" onClick="document.getElementById('deleteBox').style.display = 'block';document.getElementById('WADADeleteRecordID').value = <?php echo($row_portfolio['ID']); ?>;document.getElementById('deleteMessage').style.display = 'table';">
In the delete message:
<div class="messageContent">
          Sollen die Daten für immer gelöscht werden?<br/><br/>
          <input type="submit" value="Löschen" class="likebeyondcom" id="Delete" name="Delete" />
add a new hidden element used to capture the ID passed by the delete button onclik:
          <input type="hidden" name="WADADeleteRecordID" id="WADADeleteRecordID" value="<?php echo($row_portfolio['ID']); ?>" />
Then in the delete behavior, bind the key column to the WADADeleteRecordID form element in the delete message container.
Noa2086
thx you jason you saved my day again!
