tab index problem
Hi. Is there a way to add a tab index to an iRite text area?
Tabbing through our form, it skips the iRite textarea box despite having specified a tab index prior to making the field an iRite area.
Thank you.
NJ
Thank you.
NJ
iRite or HTML Editor?
irite uses an old version of FCKEditor that does not support tab indexes.
if you are using HTMLEditor, it uses a newer CKEditor which does support setting the tab index.
find the following line:
[$CKEditor_config["tabSpaces"] = 4;
and change it to:
$CKEditor_config["tabIndex"] = 2;
HTML Editor is rich text editor though, and tabbing is valid input, so you wont be able to tab out of the HTML editor box, you will need to manually select the next form element using a mouse click.
Not being able to tab out of the field is a bit of a problem. Kind of negates the need for a tab index really.
Thanks anyway Jason. Always appreciated.
NJ
