Power Store 4.5.3 - problems accessing admin
Thread begun 8/24/2012 9:25 am by paul386291 | Last modified 8/30/2012 7:53 am by Jason Byrnes | 3657 views | 5 replies |
paul386291
Hi there
Thanks for your response.
The store isn't set up yet as I can't access it, but the page with problems is:
PowerStore Files/admin/index.php
I copied the "show errors" code into it & it that you emailed me & this returns the following messages:
Warning: require_once(../../webassist/themes/Default/images/installed.jpg) [function.require-once]: failed to open stream: No such file or directory in /content/HostingPlus/e/n/enjoytheuk.com/web/PowerStore Files/webassist/themes/theme_open.php on line 63
Fatal error: require_once() [function.require]: Failed opening required '../../webassist/themes/Default/images/installed.jpg' (include_path='.:/usr/local/fphp5/lib/php') in /content/HostingPlus/e/n/enjoytheuk.com/web/PowerStore Files/webassist/themes/theme_open.php on line 63
I look forward to your advice on this.
Many thanks
Paul
here is a copy of the webassist/themes/Default/images/installed.jpg file saved as a php file.
copy the installed.php file to the webassist/themes/Default/images/ folder on your server.
then update the webassist/themes/theme_open.php file
change line 63:
require_once("../../webassist/themes/Default/images/installed.jpg");
require_once("../../webassist/themes/Default/images/installed.php");
paul386291
Powers Store 4.5.3 - still problems accessing admin
Hi Jason
Thanks for your help with this. However, I'm still having problems.
Being new to php code, I don't fully understand your instructions (below). How do I save a jpeg file as a php file?
I've tried copying your installed.php code into a new blank php page & saving it as installed.php, uploaded to server then amended the theme_open.php file line 63 as instructed, but this doesn't work.
I've uploaded Power Messenger & Power CMS this week with no issues, but if you can help me in more detail with this issue it would be greatly appreciated.
Many thanks
Paul
change line 63:
I'm sorry, i meant to attach a new coy of the installed.php file saved as installed.jpg for you, here it is.
paul386291
Power Store 4.5.3 - solution not working
Hi Jason
I've carried out your instructions in the previous post but I'm still getting the same error message when I try to access the admin @ this link: (index.php
I urgently need to resolve this as I have a customer waiting for their online store.
Is anyone else having a similar problem?
When everything loaded onto my servers fine with no issues on the diagnostics at any stage, I don't understand why the software is not working.
Any help you can give will be greatly appreciated.
Many thanks
Paul
sounds like you havnet updated the webassist/themes/theme_open.php file
