Still got problems!
Thread begun 8/22/2012 5:39 pm by mrs | Last modified 8/23/2012 4:19 pm by mrs | 4267 views | 8 replies |
mrs
Still got problems!
OK, so I have recreated the pages that I had issues with earlier, and I am still suffering.
I can live with the issue of my Template php code being deleted, and I can live with the menus not populating with the correct DB content, but I am unable to edit the upload files server behaviour because I can't click the finish button! Is this a bug that exists and is in need of a fix?
I am trying to update the upload files behaviour to incrementally rename the files if they already exist rather than overwrite.
Here's the code for the upload files... can you tell me what I need to change to ensure I am not overwriting:
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Update"]) || isset($_POST["Update_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "fld_bgimgNAME", "0", "", "false", $WA_UploadResult1_Params);
The finish button is not working on either the insert or upload page, so I am assuming there is a bug with it!
mrs
Also forgot to mention that when I test the page and click submit, the page stalls and does nothing but keep ticking over indicating that it is processing. I am testing locally, and it shouldn't take anything more than a second for this process to happen.
It's basically happening when I try to upload a file that is of the same name as one that already exists in the upload folder.
I have granted access to the folders for the apache server etc to allow it to write files to the directory.
Any thoughts?
Mat
yes, updating the upload behavior is a bug, see this thread for a fix:
showpost.php?p=133714&postcount=4
your other issues I addressed in the other thread you started yesterday.
For the upload issue send a copy of your page so i can see the code.
mrs
Thanks Jason, I didn't see that you had posted a comment as I only read the email that came through the forum from msummers.
Thanks to you both.
Mat
mrs
OK, I couldn't make out where I need to drop this WA_SBEngine.js file, so I did a search for it. I have 12 of them across different places on my Mac!
Where am I meant to replace this as I don't want to break something that is currently working? I know the read me info says to drop it in Library, but I have each instance in a folder called Library. Some of them are in DWCS5 library, some in DWCS5.5 Library, some in shared configuration... you get the point!
I'm running snow leopard!
Thanks in advance.
Mat
mrs
One more question.
Once I know where I am meant to replace the file, and by replacing the WA_SBEngine.js, do I then have to redo all the pages that I have the file upload facility on.
Thanks.
Mat
find the configuration folder for your version of dreamweaver. This guide will help you locate the configuration folder.
once you locate the configuration folder for your version of dreamweaver, the file goes in the following location;
Configuration/shared/webassist/library/
no, you will not need to redo the pages.
mrs
I have placed the WA_SBEngine.js file where I am meant to do so, but that doesn't fix the problems I am having on the pages that won't upload at the moment. What do I do about those as they still aren't working?
Thanks.
Mat
mrs
Sorry Jason, I've just read your note about showing you the pages for you to see the code for uploading... I'm so tired at the moment that I am missing points you are making!
I'll redo the problem pages to see if the issue has been corrected... if it hasn't, I'll ask for further help at that point.
Thanks.
Mat
