WA really needs to do up some proper docs
Thread begun 8/21/2012 9:23 am by Brad Lawryk | Last modified 8/21/2012 11:07 am by Brad Lawryk | 2700 views | 6 replies |
Brad Lawryk
So I am using the Google Maps from Design Extender .....
No updated docs. How do you make this work?
If I add an API key I get an error message, if I leave the API blank nothing shows up.
Please write some decent docs on this.
I will forward your request to our documentation team.
in the mean time i will try to help you correct the problem.
What is the error?
The Api key in version 3 is optional, so leaving it blank should work. Can you send a link where i can see the problem to investigate the cause please.
Brad Lawryk
There error tells me the API is no longer needed ...
Here is the page with the maps.
locations.php
yes, the api key is optional, the first page of the pro maps wizard has a few paragraphs above the API key input field field that talk about the api key being optional and how to obtain one.
When i visit the link you provide, the map appears to be working for me, see the attached screen shot.
Brad Lawryk
Any idea why it is only showing one location?
I am getting the addresses from a recordset and have show multiple checked.
if you zoom out, you can see the other marker,
you have the zoom level set to close to show both addresses.
Brad Lawryk
Ok thank you, much appreciated.
