ImageResizer Image Quality
Thread begun 8/20/2012 8:02 am by Christopher West | Last modified 4/19/2021 4:15 pm by Ray Borduin | 4742 views | 7 replies |
Hi
I was wondering with the latest build of ImageResizer the default image quality is 75% but I need this to change to 100% since im using thumbnails of screenshots and 75% just makes them look real bad.
Im guessing that I would need to modify CachedResize_Image.php but not sure where and what to...
in the PHP manual it states I would add a value imagejpg but there is not reference to that in the code where I can add a value to.
Chris
ok i think I found what I needed to change but just wanted to confirm thats all I needed to change:
LINE 207
$process = $image_save_func($image_c, $save_path, 100);
changed to :
$process = $image_save_func($image_c, $save_path);
are there any other parameters that I could change to improve quality of image, or was it just this line?
Chris
That looks correct, image quality only applies to jpegs and there is only the one parameter.
designweb
I am having the same problem. I need to be able to change the compression amount on my jpg files.
on line 207 my code is already set too $process = $image_save_func($image_c, $save_path);
Do I need to change this?
My images look way to compressed, I am sure that in older versions of this plugin you could set the amount, but I may be wrong.
I am using the latest version to date.
change line 207:
designweb
I tried this and it did re-cache the image as I could see the changes in github, that they had been deleted and added again, but they seem to look the same.
The original images are a lot bigger and a good resolution, so not sure why they are still looking to compressed.
can you provide a link where i can see the problem
katohkaelin443216
I am searching for this problem since last 3 days. These posts help me for solving it.
