eCart - Dynamic Cart button NOT pulling data from database
Thread begun 8/19/2012 7:28 am by tdinetta440961 | Last modified 8/20/2012 12:55 pm by Jason Byrnes | 2552 views | 3 replies |
tdinetta440961
I created an eCart button on a page in Dreamweaver expecting it to pull the sample data from the physical_database provided by WebAssist. My bindings are ID, Name, Short Description, Thumbnail, Quantity, and Price. Only the add to cart button and the quantify of 1. appears on my page in Dreamweaver?
Why is the first line in the database table not showing up? The first line in the sample physical_database is - Item Name (Remix), Item Short Description (A great collection of the hottest tunes) etc. do not appear? What am I doing wrong and what do I need to do to correct this situation.
Thanks,
tdinetta
please send a copy of the page so i can examine the code.
tdinetta440961
Page Code
Hi Jason,
Here is the code. Also, Is there a way form me to attach file images to my posts if needed?
Thanks, Tony
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
<?php require_once('Connections/MySQL_eCart.php'); ?>
$eCart1->GetContent();
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_MySQL_eCart, $MySQL_eCart);
$query_rsProduct = "SELECT * FROM items WHERE ItemID = 1 ORDER BY ItemID ASC";
$rsProduct = mysql_query($query_rsProduct, $MySQL_eCart) or die(mysql_error());
$row_rsProduct = mysql_fetch_assoc($rsProduct);
$totalRows_rsProduct = mysql_num_rows($rsProduct);
// WA eCart AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "";
$ATC_RedirectIfIn = "";
if (isset($totalRows_rsProduct) && $totalRows_rsProduct > 0) {
$row_rsProduct = WAEC_findRecordMySQL($rsProduct, "ItemID", $ATC_itemID);
if ($row_rsProduct) {
$ATC_itemName = "".$row_rsProduct['ItemName'] ."";// column binding
$ATC_itemDescription = "".$row_rsProduct['ItemShortDesc'] ."";// column binding
$ATC_itemThumbnail = "".$row_rsProduct['ItemThumb'] ."";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = "".$_POST["eCart1_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_rsProduct['ItemPrice'] ."");// column binding
mysql_data_seek($rsProduct, 0);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") {
$eCart1->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<style type="text/css">
#apDiv1 {
position:absolute;
left:10px;
top:23px;
width:182px;
height:138px;
z-index:1;
#apDiv2 {
position:absolute;
left:7px;
top:19px;
width:133px;
height:64px;
z-index:1;
#apDiv3 {
position:absolute;
left:211px;
top:21px;
width:276px;
height:128px;
z-index:2;
</style>
</head>
<body>
<div id="apDiv2">
<form name="eCart1_1_ATC_<?php echo $row_rsProduct["ItemID"]; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="eCart1_1_ID_Add" value="<?php echo $row_rsProduct["ItemID"]; ?>" >
<input type="text" name="eCart1_1_Quantity_Add" value="1" size="4" >
<input type="image" src="WA_eCart/Images/Pacifica/Btn4_EN_addtocart.gif" border="0" class="eC_ImageButton" value="Add to Cart" name="eCart1_1_ATC">
</form>
</div>
</body>
</html>
mysql_free_result($rsProduct);
