tie dynamic list/menu to data assist search page
Thread begun 8/17/2012 6:10 am by sfj6167 | Last modified 8/21/2012 8:48 am by Jason Byrnes | 3938 views | 7 replies |
sfj6167
Hi there
Have generated administration pages from data assist.
On the insert page a group value is set to every user - users,superusers,administrator
on the search page I have a rs that list the group values from the group table.
users,superusers,administrator in the search form.
when I try to search for group id (lets say administrator ) and click search
it just returns all users...
What am I missing ?
regards
bison
Did you add this after running the wizard to create the search and results page?
you will need to edit the Data Assist Search behavior on the results page to add a new criteria for filtering the group id column using the select list.
sfj6167
Hi Jason
Yes after using Dataassist to create the standar administrative user pages, I added
the UserGroup to the insert page, and that works fine
on the update page I also put in the UserGroup field to retrieve this information from the users table. That also works fine..
Then on the Search page I created a rs for bringing in the men/list for UserGroups and on the results page I added the field for filtering...
that should be right ???
but it dont works, it just returns all posts
regards
bison
This is the field I have set in on the users_search.php
<li class="formItem">
<div class="formGroup">
<div class="lineGroup">
<div class="fullColumnGroup">
<label for="UserGroupID" class="sublabel" >Bruger Type:</label>
<div class="errorGroup">
<div class="fieldPair">
<div class="fieldGroup">
<span>
<select class="formMenufield_Medium" name="UserGroupID" id="UserGroupID" tabindex="13">
<option value="value">Vælg gruppe</option>
do {
<option value="<?php echo $row_WADAMenuUserGroupID['UserGroupID']?>"><?php echo $row_WADAMenuUserGroupID['UserGroup']?></option>
} while ($row_WADAMenuUserGroupID = mysql_fetch_assoc($WADAMenuUserGroupID));
$rows = mysql_num_rows($WADAMenuUserGroupID);
if($rows > 0) {
mysql_data_seek($WADAMenuUserGroupID, 0);
$row_WADAMenuUserGroupID = mysql_fetch_assoc($WADAMenuUserGroupID);
</select>
</span>
</div>
</div>
</div>
</div>
</div>
</div>
</li>
In DataAssist Search (WADAUsers) on the users_results.php page I`ve
added a filtered field:
Type EDIT
Separator AND
Column UserGroupID
CT = N
Value USerGroupID
Type of field is set as List
send a link where i could see the problem please and a copy of the search and results page.
sfj6167
Sounds great Jason
site is www.kameraservice.dk
last menu to the right contains:
users
search user
insert user
regards
bison
on the results page, change:
if ($_SERVER["REQUEST_METHOD"] == "POST") {
if ((isset($_GET["Search"]) || isset($_GET["Search_x"])))  {
sfj6167
Hi Jason. Changed the code as you said on line 33
filtering on groupid now works, BUT
none of the other fields do.
if you filter on other fields than groupid you get "no results"
and when you then hit "users" from the menu it wont show the results on the
results page, its getting stuck on just showin "no results"
Please advise
regards
Bison
