Restrict Content Import
Thread begun 8/16/2012 3:18 pm by tpellison430660 | Last modified 5/21/2014 9:26 am by Jason Byrnes | 4691 views | 5 replies |
tpellison430660
I'm using the Restrict Content validation. If I click on Import I see one file (or option) of Swear Words. Is there any info or threads on exactly how this works. I'd like to maintain my own file of offensive words and use this validation type. If it works the way I hope it works, I can maintain my own list and have it apply site wide to any validation that uses the restrict content.
this is not how the import feature works.
the import feature allows you to set your own list of restricted words in the validation behaviors, then export it as a preset that can be used the next time you add validation to a page.
if you edit the preset when adding it to another page, the changes do not apply site wide.
It is posible to create your own master file of restricted content to use site wide, but it will require some hand coding to accomplish.
first off, the restrictions that you add to the list follow a specific format based on type. They are added to a comma separated list, the restricted word first, then a pipe and the replacement word. In server validations, the replacement word is not really important though, since nothing will be returned if the validation fails. the type of restriction is determined by the way the spaces are arranged around the restricted word and replacement word.
here is an example that shows the format of each:
" exact | exact "
" includes|includes"
" begins| begins"
" ends |ends "
in the code, each would be strung together as a comma separated list:
" exact | exact , includes|includes, begins| begins, ends |ends "
to create your own master list, you could create a new php file that is completely empty, and add a variable that is set to the restricted content string:
$notCool
save the file as restricted.php. add a require once line to the form php file:
<?php require_once("restricted.php"); ?>
when you add the restricted content validation, the code will look similar to this:
[php]$WAFV_Errors .= WAValidateRT(((isset($_POST["textfield"]))?$_POST["textfield"]:"") . ""," exact | exact , includes|includes, begins| begins, ends |ends ",true,1);[php]
you can change that to use the $notCool variable defined in the restricted.php page:
$WAFV_Errors .= WAValidateRT(((isset($_POST["textfield"]))?$_POST["textfield"]:"") . "","".$notCool."",true,1);
just make sure to use the correct format when adding restricted content to the $notCool string.
quy355499
Is it possible to delete presets that I have created?
use the preset manager.
WebAssist -> Preset Manager
select the Preset you wish to delete and use the delete button.
quy355499
OK. Sorry I may have used the wrong terminology. I am looking for "Swear Words" list and my custom lists to manage.
no, there is not a way to delete one of the import presets.
