auto increment number in universal email
Thread begun 8/16/2012 10:21 am by teresa328019 | Last modified 8/16/2012 11:13 am by Jason Byrnes | 1239 views | 1 replies |
teresa328019
I'd like to add a number that automatically increments starting at 8302 to be emailed each time a form is filled out.
This is what I currently have:
$MailBody = $MailBody . "\r\n";
$MailBody = $MailBody . ((isset($_POST["fname"]))?$_POST["fname"]:"");
$MailBody = $MailBody . "; ";
$MailBody = $MailBody . ((isset($_POST["lname"]))?$_POST["lname"]:"");
$MailBody = $MailBody . "; \r\n";
$MailBody = $MailBody . ((isset($_POST["address1"]) && $_POST["address1"] != "")?$_POST["address1"]:"address1 ?");
After the address field, I'd like it to insert the auto number. Do I need to have it connected to a database to do this? Currently, I don't have the information going into one.
yes a data base would need to be used in order to keep track of the number to get the right increment.
create a database table and use the Data Assist Insert record behavior to store the form data .
the insert record behavior stores the ID of the record that is inserted to a session variable.
you could use the session variable to show the incrementing number.
after you create the table, you can run the following query:
ALTER TABLE tblName AUTO_INCREMENT = 8302;
this will set the starting point of the auto increment to 8302
