Double opt in Tutorial Typos
Thread began 8/15/2012 1:45 pm by elevy388997 | Last modified 8/15/2012 1:55 pm by Jason Byrnes | 760 views | 1 replies |
elevy388997Beta Tester
In this tutorial - data_bridge_create_double_opt_in_reg.php - there are a few typos that might be confusing.
Add Email Verification Links
"11.After the ?id=, drag the SecurityAddist_UserID binding from the Session list in the Bindings panel." (spelling)
"14. After the bindings, add the following text:
?email=
15. After the &email=, drag the Registration_group_Email binding from the Registration_Basic_Default list that we created earlier in the Bindings panel." (should it be ?email= or &email= )
"16. Copy the full URL + URL variables."
Also when I drag that binding in from the bindings panel, it is displayed as a tiny php icon, so when I cut the long url and make text a hyperlink, it ends as email= ...blank. So i'm guessing I should be cutting and pasting the code view code and not the design view text.
I have forwarded this to our documentation team, thanks for bringing it up.
In the links, only the first URL variable should be proceeded by a ? the others should be separated by the &.
when copying the code for the link, you should be using code view not design view.
