remove commas and rename file on upload
Thread begun 8/14/2012 10:45 am by Sweens | Last modified 8/14/2012 11:39 am by Sweens | 6522 views | 2 replies |
Sweens
Hi
Using UE4 file upload facilities, which works very well. An issue has just come to light when trying to do something with images that have a comma in the file name.
How can I rename files on upload so that any commas are stripped out of the filename? (It would still need to increment the file name if the same name already existed)
many thanks
Chris
add the following code to line 1 of your page:
// Code added to strip comma from uploaded file name
if(isset($_FILES['fileField']['name'])) {
$_FILES['fileField']['name'] = str_replace(",","",$_FILES['fileField']['name']);
replace fileField with the name of your file field.
Sweens
thanks Jason - works a treat.
art226587
I have to strip out apostrophes (') and this solved my filename problem. But now the user isn't redirected to the correct page upon insert complete ($WA_redirectURL = "thanks.php";). The same form page just reloads even though the data is being captured and the filenames are rewritten correctly. Please help!
most likely an error is occuring to prevent the redirect.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
most likely the error is the Headers already sent error which can be caused by a space at the end of a closing php tag:
or a blank line between the closing php and an opening php tag:
see this thread for details:
showthread.php?t=19285
art226587
Thanks, Jason. I reverted back to an earlier version of the file and now it's working.
