'file not found' workaround?
Thread begun 8/14/2012 9:37 am by Airfox | Last modified 8/16/2012 5:06 am by Airfox | 1961 views | 2 replies |
Airfox
Hi guys,
I am working on a refit for a real estate site. We've copied the database across, which contains the image file names and most of the images have been harvested from the old website. I occasionally bump into an image that is missing. The database has the file name, but we just don't have the file; I have to manually go grab it from the old site. Is there a way of setting a 'file not found' image that would be used if the required image file is missing?
Many thanks.
this would require hand coding using the file_exists() function:
function.file-exists.php
for example:
<?php if (file_exists("path/to/images/".$row_recordsetName['imgColumn']."")) { ?>
<img  src="path/to/images/<?php echo $row_recordsetName['imgColumn']; ?>" />
<?php } else { ?>
<img  src="path/to/images/default.jpg" />
<?php ?>
Airfox
Beautiful! Works perfectly.
details2.php?propertyID=1106
Many thanks Jason
:o)
