Ecart Testing
Thread begun 8/14/2012 7:30 am by Php | Last modified 8/16/2012 11:59 am by Jason Byrnes | 3328 views | 5 replies |
Php
Ecart Testing
Apologies if this has been asked before. I am developing a testing shopping website and just on the stage of adding the e-cart. My question is that the e-cart system requires a working paypal account however is it possible to test the e-cart on a testing server such as xampp?
Many Thanks
Yes, you can use XAMPP for testing, but you will need to enable cURL:
showpost.php?p=131075&postcount=2
one thing that wont work though is sending emails.
Php
Thanks for replying, Would I need to setup a paypal account to test the e-cart on the xampp or is there a way to bypass the payment to test the e-cart of my shopping website.
you will need a paypal account if you select to use paypal as the payment gateway when running the checkout wizard, or you can select to use no gateway in the checkout wizard.
Php
If I use no gateway in the checkout wizard would that bypass the payment? I am developing a testing shopping website and it's being tested on xampp. Thanks
using no gateway in the wizard would not pass the transaction to a gateway.
