Framework builder issue
Thread began 8/13/2012 5:28 pm by mmnpinto361034 | Last modified 8/15/2012 9:10 am by mmnpinto361034 | 640 views | 2 replies |
mmnpinto361034
Using framework builder to conect a page where i've got a form. The problem is that all css breaks and in the page the form apear with no css. It seems to me that the problem is due to this metatag: <meta http-equiv="X-UA-Compatible" content="IE=Edge" />
When i remove it everything is ok. This only happen with IE (in this case IE9) because on google chrome and firefox i've no problems
Is there any incompatibility of framework builder with this metatag and IE9???
Got no page link to provide because the website is being constructed. Everything is tested localy.
Hope for a quick solution!
I am not able to reproduce the problem.
I created a form using form builder and added it to a page using framework builder, then added the meta tag you mentioned to both the form page and the plugin page, and the form CSS Is showing fine in IE and other browsers.
I will need to see the problem in order to troubleshoot.
mmnpinto361034
Dreamweaver cache
Hi Jason,
you're right. It seems to be a dreamweaver cache problem. When i clean the cache it works, but stangely i've to do it every time a decide to use the framework builder.
