Add to cart not working when live
Thread began 8/13/2012 9:09 am by willo009412397 | Last modified 8/13/2012 7:30 pm by willo009412397 | 708 views | 2 replies |
willo009412397
Hi
My websites cart functionality works when running local, but now its uploaded online it will not work. It will not add any products to the cart, and just says `shopping cart is empty`. I have enclosed my Details.php and Cart.php to look at. If needed you can view it here :www.printingcolouruk.co.uk .Thanks for any help.
Regards Karl
New folder.zip
First thing to check is that server can properly save session information.
use the sessionTest.php file from the following thread to test the servers session management:
showpost.php?p=23826&postcount=2
if the session test fails, it is most likely the session.save_path setting in the servers php.ini file, you will need to contact the host to have them correct the issue.
willo009412397
Thanks Jason
The test comes back as NULL, i had an idea it was a sessions issue as my pages which use SecurityAssist also will not work. Thanks for your help, i will contact web host.
Regards Karl
