checkout issues
Thread begun 8/12/2012 4:43 pm by johna1964 | Last modified 8/13/2012 1:28 pm by Jason Byrnes | 2135 views | 3 replies |
johna1964
checkout issues
Hi!
Two questions that seem to be coincide:
I recently made some changes to the site. By changes, I mean applying the SSL to the cart.php and checkout.php pages according to the tutorial.
I noticed the eCart Checkout Button server behavior on the cart.php page now has a red exclamation mark... I don't know if this is incorrect or how to correct it if it needs correcting.
Also, since the applying the ssl to only the checkout pages, the checkout does not carry the cart items to the cart page. This is only occurring in IE at this time.
The files are attached.
Thank you!
johna1964
a red exclamation mark only means there may be a problem.
to look into the problem with cart items carrying over, i will need a link where i can see the problem occur.
johna1964
Hi Jason,
What is happening is when I double on the eCart Checkout Button server behavior, the following message appears:
"Please ensure that you selection in inside the body tag before using this object."
I am definately inside the body tag and in code view and split view.
Any suggestions?
Thank you.
johna1964
your using a checkout form now instead of the standard eCart checkout button.
instead of editing the server behavior (Which can be deleted since you deleted the original checkout button), you need to edit the checkout forms action to change where it points to:
<form name="ecart_checkout_form" action="https://ecigaretteimpressions.com/checkout.php" method="post">
