Repeating table
Thread begun 8/10/2012 10:20 am by john70964 | Last modified 8/15/2012 3:51 am by john70964 | 2458 views | 4 replies |
john70964
Repeating table
On a page using a template I tried to insert a Data Assist Repeating table.
But when I do most things disappear.
Please see pictures
Thank you
John
does it render correctly in the browser?
Can you send a before and after copy of the page please?
john70964
Thanks Jason
No it does not render correctly.
There is an error message Parse error:
syntax error, unexpected '*' in C:\xampp\htdocs\boatsforsalenow\index.php on line 31
I am attaching the before index.php
and after index2.php
john70964
Thank you Jason for the very useful contact regarding this above problem.
I have been taking this subject a little further and have made some progress.
To enable the repeating table to show correctly on my machine I found I needed to select the Bindings tab in order to show the Recordset.
If the Recordset is shown and or selected via the Server Behaviours tab the repeating table is not created correctly.
I also had to change the Repeating Table code a little and move the opening <?php above the opening <tr>
<table width="734">
<?php do { ?>
<tr>
and balance the bottom as:
</tr>
<?php } while ($row_rsBoats = mysql_fetch_assoc($rsBoats)); ?>
</table>
This note may assist me or anyone else as a reminder.
John
