Block UEmail when cart is empty ?
Thread began 8/08/2012 10:31 pm by Fritz Stickers | Last modified 8/10/2012 8:22 am by Jason Byrnes | 2069 views | 10 replies |
Fritz Stickers
Is it possible to block UEmail when the cart is empty ?
Some customers like to play around with the back-button and sent their order (empty) twice or even three times. Though when submitted the checkout-page, the cart is empty and the session is abandoned. But an email is sent.
On the page with UE on it, there should be a Redirect If Empty Behavior, Move that behaviors code so it is before the UE code block, this will prevent the email from sending if the cart is empty.
Fritz Stickers
Do you mean this piece of code ?
' WA eCart Redirect
if (stickersBE_redirStr <> "") then
Response.Redirect(stickersBE_redirStr)
end if
This is just before the "Session.Abandon" and <!DOCTYPE html .....
yes, copy that code and place it before the UE code block.
Fritz Stickers
Sorry, but that doesn't make a difference.
send a copy of the page please
Fritz Stickers
Please see attach.
Redirect.zip
sorry, i had the wrong code block, This page doesn't have a redirect if empty behavior on it.
Go to the server behaviors panel, click the plus button and select eCart -> General -> Redirect if empty to add one.
once it is added to the page, move it to be before the UE code block.
Fritz Stickers
OK ... thanks ... that's working fine.
Fritz Stickers
One little thing still occurs ...
When the customer clicks the back-button after he confirmed (on confirmed page) and submits the checkout page again, he will be redirected to the page from the "eCart Redirect If Empty" behaviour. No mail will be sent, that's ok.
Also there is no record added in the database, although the orderID-number of the following order increases with two.
Most likely is it due to "eCart Store Cart Summary (& Details) in Db" !?
Is there a way to prevent this ?
