Redirect issue, despite replacing library.php
Thread begun 8/08/2012 10:42 am by Justin@AdventDesign | Last modified 8/10/2012 10:43 am by Jason Byrnes | 2041 views | 3 replies |
Justin@AdventDesign
So after a fresh install of DataAssist on my laptop, I ran into the wrong redirect file path issue you noted in the sticky. I had the same problem on the desktop ages ago, and remembered, and followed the instructions on the sticky. I've replaced the library.php file within the site, as well as within dreamweaver's files, but I'm still running into the redirect issue. I've tried different browsers and dumping the cache, and still get the problem. Where do I go next for troubleshooting?
look for the following line:
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
and comment it:
//if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
Justin@AdventDesign
That appears to fix the problem. So what is different about this one than others?
Not really sure to be 100% honest.
The Rel2Abs line is really only needed if you are Framework builder to add the data assist forms as an Include. if your not using framework builder, commenting that line will have no effect.
