WA_ProcessingObject.js
Thread begun 8/04/2009 6:11 pm by matthew334024 | Last modified 9/03/2010 8:27 am by Jason Byrnes | 3617 views | 3 replies |
matthew334024
I get an error from Site Import 3.02 on Mac OS X and Dreamweaver cs3 that WA_SiteTools_Progress.htm has a JavaScript error in line 583; it gives a drive location that doesn't exist (Dreamweaver cs3: configuration: floaters: WA_progress: WA_ProcessingObject.js) and says there's an exception thrown in native function. The extension hangs. I tried reinstalling, no joy. The other extension I have is CSS Sculptor 1.5. What's my next step?
Matthew
This issue appears on pre-release versions of Dreamweaver CS3. The extension should work on the released version (Build 3481). This is a known issue in Dreamweaver Build 3453.
Please make sure your Dreamweaver build is 3481 or greater. This has been verified and will work on working versions of CS3. To find out the build you are using go to About from the Dreamweaver menu in Dreamweaver and click once to forward to the version number and build.
If this is not the case then it is likely an issue with a corrupt config or maybe even a cache file problem.
joe363479
The same problem with Dreamweaver CS4
I'm using CS4 on OSX and getting the same error relating to CS3 . . . I've deleted the cache file but still no success
What version of Site import are you using?
the most recent version is version 3.0.4, make sure this is the version you have installed.
if you already have this version, what other extensions do you have installed, can you send a screen shot of the extensions manager showing the installed extensions and their versions.
