deleting an entry
Thread begun 8/06/2012 1:25 pm by JamieEff | Last modified 8/08/2012 10:12 am by Jason Byrnes | 4060 views | 7 replies |
JamieEff
deleting an entry
Hey guys
Just had a support session with Ray, but am trying now to figure out how to be able to delete an entry.
basically, my client is able to add a company to the database but I dont know how to allow him to delete a specific entry.
At the moment my code is
<div><a href=""><?php echo $row_Clients['UserFirstName']; ?></a></div>
<div><?php echo $row_Clients['UserEmail']; ?></div>
<div style="float:left;width:185px;margin:0 0 0 4px;"><?php echo $row_Clients['UserPassword']; ?></div>
<div>
<form action="clientarea-list.php" method="delete" >
<input name="Submit" type="image" id="Submit" src="images/misc/delete.jpg" width="20" height="20" alt="Delete"/>
</form>
</div>
I think my form action (so far) is right, but I dont know how to get it to delete the entry that it is related to in the repeat region....
Cheers
Jamie
you need to add a hidden field that will pass the ID of the record to delete.
Then in the delete record behavior, set the Key value to use the hidden element.
JamieEff
sorry to be a pain and to be thick, but how do I go about doing that?
Jamie
well, the recordset on your page should return the ID column.
add a hidden form element to your form, and bind the initial value of the element to the ID column from the recordset.
then add a delete record behavior, in the delete record behavior, set the key column to the ID column and bind the key value to the hidden element.
JamieEff
OK Jason, but I just dont know how to do that....
If you couold give me a step by step guide of how to do it and how to set it up I would really appreciate it.
to add a hidden form element go to insert -> form -> hidden element.
to set the initial value for the hidden element, select it in design view, then in the property inspector, click the lightning bolt next to Initial Value and select the ID column from the recordset binding group.
to add a delete record behavior, open the server behaviors tab, click the plus button and select webassist -> Data Assist -> Delete -> Delete Single record.
JamieEff
thanks very much Jason
Got that all working with thanks to you and to Ray...
I have added that delete function to a part of the site but when I click on delete (image 1) the resulting 'action' takes me to image 2
I then have to click back to actually see the page with the item removed...
How would I get it to do that part automaticallY
Cheers
Jamie
Does the page take any URL Variables at run time?
if so make sure the form is passing them as part of the action.
also, make sure the delete code comes before the recordset on the page.
