rotator.php doesn't work for me
Thread begun 8/04/2009 5:32 pm by mick106153 | Last modified 8/06/2009 11:28 am by I-CRE8 | 6494 views | 5 replies |
mick106153
Not a WebAssist question.
I'm trying to incorporate rotator.php so a different image is displayed in certain areas of the page each time it is reloaded. You can read about it here.
rotator.php
I'd like to use this one because it can size the images and carry a link so that I could display different products which could be clicked on for purchase.
The errors are:
Notice: Undefined index: id in /Users/mick/Sites/intuHorsesPowerStore/rotator.php on line 44
Notice: Undefined index: class in /Users/mick/Sites/intuHorsesPowerStore/rotator.php on line 48
If I comment those lines out it leads me down a path of subsequent errors. It should be obvious that php is not my strong suit and others seem to have no trouble with this code.
Please comment if you can.
Line 44 is - $id = $images[$img]['id'] ?
Line 48 is - $class = $images[$img]['class'] ?
Mick
Read me and php follow.
READ ME
"Hivelogic Image Rotator
This PHP script and accompanying `.ini` file will rotate an image from a pool of images every time a web page is visited (or reloaded).
Unlike JavaScript-based image rotators, this is a server-side script and the rotation happens when the page is loaded.
Installation
For the most basic installation, just drop the `rotator.php` file along with the `images.ini` into the same folder on your webserver.
You'll need to include the rotator.php file in your current page. The easiest way to do this is using the `include` directive near the top of your page:
<?php include('rotator.php'); ?>
Edit the `images.ini` file and create a few code blocks to point at your images, specifying the source, alt tag, url, and title tag for each image, like this:
[Doctor]
src = img/drwho.jpg
alt = Tom Baker
url = doctorwho/
title = Dr. Who
You can also specify images on remote servers if you want, like this:
[Kubrick]
alt = Stanley
url = www.kubrick.com/
title = Kubrick
Then add the following image tag into your web page:
<?php showImage(); ?>
Reload the page, and you'll see the different images appear each time.
You don't have to determine an image's height or width yourself - the script will handle it for you, and generate the proper `img` tag on the fly once it has randomly selected the image.
Multiple Rotating Images
You can display different sets of rotating images by specifying different configuration files like this:
<?php showImage('plugins/myprecious.ini'); ?>
You can do this as many times as you'd like, on any page you'd like, or even multiple times within the same page.
Linkless Images
If you want to display images without linking them, just leave the url value of the image entry in the config file blank, or omit it entirely. If the rotator code doesn't find a URL, it will simply output the img tag without the surrounding a href tags.
Custom CSS ID's or Classes
Optionally, you can specify both an `id` or `class` tag in the configuration file, like this:
[Doctor]
src = img/drwho.jpg
alt = Tom Baker
url = doctorwho/
title = Dr. Who
id = my_id
class = my_class
If the rotator script finds them, it will add them to the `img` tag. optional."
ROTATOR.PHP SCRIPT -
Author: Dan Benjamin - hivelogic.com/
Copyright (c) 2004-2009 Hivelogic Corporation. All Rights Reserved.
THIS SOFTWARE IS PROVIDED "AS IS", WITHOUT ANY WARRANTY OR CONDITION OF
ANY KIND, EXPRESS, IMPLIED OR STATUTORY, INCLUDING WITHOUT LIMITATION ANY
IMPLIED WARRANTIES OF ACCURACY, MERCHANTABILITY, FITNESS FOR A PARTICULAR
PURPOSE OR NONINFRINGEMENT.
IN NO EVENT SHALL DAN BENJAMIN, A LIST APART, OR AUTOMATIC, LTD. BE LIABLE
FOR ANY DIRECT, INDIRECT, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES OR
LOST PROFITS ARISING OUT OF OR IN CONNECTION WITH THE SOFTWARE (HOWEVER
ARISING, INCLUDING NEGLIGENCE), EVEN IF DAN BENJAMIN OR HIVELOGIC CORP.
IS AWARE OF THE POSSIBILITY OF SUCH DAMAGES.
# file containg your image descriptions
$IMG_CONFIG_FILE = 'images.ini';
# You shouldn't need to change anything below this point
function showImage( $ini=null ) {
global $IMG_CONFIG_FILE;
# if no custom ini file has been specified, use the default
$ini_file = $ini ? $ini : $IMG_CONFIG_FILE;
# read the config file into an array or die trying
$images = @parse_ini_file($ini_file,true);
if (! $images) {
die('Unable to read ini file.');
# pick a random image from the parsed config file
$img = array_rand($images);
# get the selected image's css id if one exists
sprintf( ' id="%s" ', $images[$img]['id'] ) :
# get the selected image's css class if one exists
sprintf( ' class="%s" ', $images[$img]['class'] ) :
# get selected image's dimensions
$size = @getimagesize( $images[$img]['src'] );
# if an url was specified, output the opening A HREF tag
if ( $images[$img]['url'] ) {
printf(
'<a href="%s" title="%s">',
$images[$img]['url'],
$images[$img]['title']
# output the IMG tag
printf(
'<img src="%s" alt="%s" %s %s%s/>',
$images[$img]['src'],
$images[$img]['alt'],
$size[3],
$id,
$class
# if an url was specified, output the closing A HREF tag
echo('</a>');
I-CRE8Beta Tester
Mick,
your server is set to show warnings as well as errors and it is complaining that your ini file does not contain an id and class value.
The answer is to supply a blank value for each image like so:
[Doctor]
src = img/drwho.jpg
alt = Tom Baker
url = doctorwho/
title = Dr. Who
class =
id =
[Kubrick]
alt = Stanley
title = Kubrick
class =
id =
mick106153
Well Duh!!
That was pretty obvious.
I feel like a fool.
Never overlook the small stuff.
Thank you
Mick
I-CRE8Beta Tester
No worries
mick106153
Just made the change and it works like a charm.
Thanks again
Mick
PS.
Any way to time this script so that it could fire without a page reload?
I-CRE8Beta Tester
No problem, glad it worked.
To fire the script you need to trigger a page reload, the only alternative would be to use a JavaScript Rotator
